| USA Talk to others in your region. |
![]() Join Date: Dec 2003
NORCAL:Can anyone wanna help me install new clutch
Well it looks like i need a new clutch... i read a couple of threads stating it's easy when u have a space and tools to do it... i wanna give it a shot and also save some $$$... any locals wanna give me a hand... any help will be very appreciated
Thanks in advance
AIM: ghst01 http://www.cardomain.com/ride/585615 http://www.myspace.com/8407376 96 red zenki: Greddy KA Turbo kit (TD06-20g, 370cc, Emanage, Vspell FMIC), TEIN HE's, VIS Vader CF hood, Falken Azenis ST-115's, Sony Xplod head unit. |
![]() Join Date: Jul 2003
i second that motion! even if u have a big area, itll be hard to do it unless u have a lift. If you do take it to a shop can u post up how much it was or PM me cuz i need to resurface my flywheel. Thanks
Well this place called "Discount brake and Clutch " is quoting me $379 for a new clutch kit and to resurface the flywheel.... made an appointment for Sat....hopefully it will be something easier to fix so i wont have to spend to much $$$.. They are located @
740 Valencia St (between 18th and 19th) S.F. CA 415.431.3700
![]() Join Date: Sep 2003
a new clutch kit , resurfacing the flywheel....and what about labor? if that's included i'd question the quallity of the clutch kit they are selling you..not that's it's bad quality but think about the way we drive. you want something that will hold up.
Hi |
![]() Join Date: Mar 2003
if that is clutch plus labor, it's a good deal. Most of the time shops want about 150+ for labor.
I dread it everytime I have to do a clutch on my car. Sucks balls! Luckily my brother is a competent mechanic as well. You really need to have another competent mechanic with you if you are pulling the tranny.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing. |
well they quoted me that price for everything including resurfaceing the FlyWheel. plus it comes with 3 year warrenty on parts and 1 year on labor
driftLadie: Yea it's the same since the drive that day. the weird thing is that the car feels alright except for the pedal not coming back as far as it used to and the shifter feeling more loose.... might be a line or something when i hit that bump when sparks came out from under the car.....
you are definitely losing pressure somewhere Al. if the pedal feels mushy ..could be a line.. if you pump the clutch pedal a few times does it build more pressure?
Hi |
#14 | |
WestboroughPIMP: i have tryied to pump it a couple of times but still no luck.
well i am trying to save up for my turbo kit so i think ima just go OEM for now
#17 |
I just changed my clutch cause my stock clutch fried cause of the turbo, I don't know what the big deal is about changing a clutch. Unless your trying to Mount an S14 Tranny into an S13. ::Cough:: (David)
Second you said that your shifter is feeling loose. Um, I think I would check your Tranny mount before you mess with your clutch, cause the clutch has nothing to do with your shifter feeling loose, Either something inside the shift assemble got fucked or your mount got fucked. If you hit hard and sparks and the whole works you might have damaged something else. Just my 2 cents, but that's the way I see it.
David Munoz, 1989 S13 KA24ET 1990 Infiniti Q45 To push oneself to the limit is all that one can do. To quit is to die. |
#19 |
Well we will see tomorrow when i take it to the shop
#20 | |
![]() Join Date: Aug 2002
you also probably need at least 3 guys to help put the tranny back on, or 2 really big guys. its doable, and i was able to do everything in my garage up till the part of putting the tranny back on. all it takes is a bunch of elbow grease and determination. i know after all was done, i told myself i would never do it again. but that was about a year ago and im willing to take the challange again. i know ill probably be regretting it when im under the car w/ bruises and cuts and bitching the shit outta my car but for now, im up to it. |
#21 |
it turned out to be just the master cylinder rod that broke and slave cylinder that was leaking.
#22 |
heh hmm imma check out that place this tuesday mayb. My flywheel is almost gone so damn..... whats worse is that i need tires BADLY! AND im gettin fired cuz i havent been payin for the union
#23 |
![]() Join Date: Feb 2003
yea..changing clutch aint too hard but time consuming and a lot of things to remember...i did it with my friend in front of my house..2 jack stands, 2 scicorr jacks, 1 cheap ass hydraulic jack..some sockets/wrenches..and my stock exhaust piece as a breaker bar..can't get n e ghettoer than that..but with those conditions and putting about 75% effort into with 25% of messing around, took us a good 7-8 hours. Mind you this is for the SR, not the KA. The KA is easier since the tranny comes right off. I had to deal with the stupid firewall...~_~
89 240sx Coupe |
