HELP need to figure out what these parts are.. PICS inside.
So my buddys putting together my s13 blacktop sr20det for me and the guy at the machine shop kind of messed up these parts when he was taking it apart. Just trying to figure out a part number or where I can buy them brand new.
1st part is right behind the thermostat housing and the waterpump on the intake manifold side. 2nd part is directly under the exhaust manifold on the right side. Any help would be greatly appreciated. Thanks. |
You won't be able to remove or install those parts with the cylinder head on, unless you cut a portion off on the pipes. I did that once a long time ago and could not get them to fit. The larger pipe that is the water pipe to the cylinder head, the other one is the Crank ventilation pipe. Those are pretty hard to come by, and I have yet to see any new. The turbo RWD engines are different than the FWD engines, so don't try and cross refrence them to the FWD engines available in the US.
