hello friends, Thanks for the previous answers, I want more advice from you, my goal is 350hp at the flywheel, I already know that the gr2560r cannot go beyond 320hp, too bad because it would have had little turbo lag, I know that the gr2860rs goes up to 350hp (but maybe it sends hot air), maybe I need a gt2871r, I am undecided I have never used these turbines on a ca18det, obviously I want the least possible delay, which turbo do you recommend? trim? A.R?
N.B !!! I am undecided air-air air-water intercooler ?? : Duh: with the air-water Intercooler I would have more air but very fresh = less detonation, normal petrol engine to be assembled, completely forged new, km 0,: D |
You won't make 350 with a 2860rs. Go for the GT2871r, it spools up plenty fast. My forged CA18 hits full boost at about 3700 I believe, with my GT2871r with 48 turbine wheel trim and .64 a/r. I recommend the more common 56 trim wheel as it gives you about a 380 whp cap, or so they say. Check out my build thread if you want some more details about building a CA18. https://forums.nicoclub.com/izento-s...70089-150.html
