S14 sr20det needs rebuild will include ecu, harness, flywheel, z32 maf tomei arm 8270
S14 SR20DET Sold
I'm in Houston texas I bought this motor a while back with intentions of rebuilding it, head was machined/ arp head bolts and a metal corsworth head gasket were installed by previous owner. Was told it still had low compression, i never tested myselft i was gonna build it anyways. Aftermarket parts - New eagle rods - Tomei expreme manifold and elbow - Tomei m8270 arms turbo kit (used only at 3 events) still newish - new power enterprise super kevlar alternator belt Stock parts -z32 maf with wiring specialists connection -(wc) ecu -trans -flywheel -starter -s15 alternator -engine harness Cons parts not included ( you will need to buy) -SR can angle sensor -fuel rail -injectors -coil packs /harness -clutch Last edited by short-shifter; 07-26-2018 at 09:15 AM.. |
| eagle rods, sr20det, tomei |
