![]() Join Date: Dec 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 13 reviews
S13: S&W 10pt Roll Cage & Megan Rear Strut TowerBrace...
Hey guys,
ROLL CAGE SOLD! STRUT BAR SOLD! Last edited by gills; 04-08-2013 at 09:26 AM.. |
I forgot to mention and post pics of the spreader/mounting plates that come with kit. There's 8 1/8" thick, 6"x6" mounting plates that come with it.
PMing you... |
i have a question even thought enjuku says "1989-1994 Nissan 240SX, through dash, 1-5/8 x .134" wall EWS tubing,(More for shows, most likely will not pass any sort of motorsports tech.)
11-5594TD-CM 89-95 Nissan 240SX thru Dash, 1-5/8 x .083" wall moly tubing, (More for shows, most likely will not pass any sort of motorsports tech.) " you think after welding in it would pass inspection for like A class shit.??? |
#6 | |
So with that said, yes, don't expect to install ths and run a SCCA/NASA race. It does have a nice thick wall though and will fit with an interior still intact, which is cool for a weld-in cage. Also, it's very inexpensive for a cage! |
lil bump^^
I also want to add that just because this cage wouldn't pass professional sanctioned motorsports tech inspections doesn't mean you wouldn't be safer if you had this in your car versus not having anything at all (obviously installed and welded professionally) if you just attend regular track days (HPDE's) or other non-competitive high performance events. This cage plus a 5 or 6 point harness would definitely be safer than nothing and your everyday 3 point seat belt. bump^^^ |
![]() Join Date: Sep 2011
Hey, I would recommend getting a freight quote yourself. I just had a complete engine/tranny shipped to me from NJ for less than $400. They go by weight, working it out backwards I paid about $0.70/lb. If you can get a legit shipping quote, I'm interested.
Besides, Enjuku does not stock these roll bars, they drop ship directly from S&W so the shipping quote was not accurate in your case since they are in PA. |
#10 | |
So do you want to PM me your address? I'll be more than happy to get you an accurate quote if you truly are serious. Let me know. |
MiamiZ33, sent you a PM with an actual shipping charge.
Some more info: This cage can actually be used in some sanctioned events. 24 hours of Lemons (24 Hours of Lemons - Home Page) and ChumpCar (ChumpCar World Series | home) requirements for sub 3000lbs cars is 1.5" OD x 0.120" wall OR 1.75" OD x 0.95" wall tubing so the 1.625" OD x 0.134" wall dimensions of this S&W cage would pass tech. As for the rear strut bar, make me some offers! |
bump^^^
I added an illustration showing the arrangement of this cage that will help visualize how it goes together. Any questions, please don't hesitate to ask. -Tom |
#21 | |
| megan, roll cage, s&w, s13, strut bar |
