rb20 code 12
Got a code 12 on my ecu. Looked at the wiring and it has been lengthened but was done good. Cleaned the maf and the filter for it. Now car will idle then die randomly. Only part that looks to be bad is this
ok new question. at key on maf is reading .45v at idle(1500 right now) its read 1.24v. Heard its suppose to be 5v. Also guy on here said if i had a safc on it before(previous owner did) it can cause that issue?
