Leaking head gasket?
I recently bought an apexi head gasket for my s13 sr20det, and when i installed it and torque it to spec and in sequence, it's still leaking a good amount. Why is this happening? The head or block deck isn't warped or anything like that.
head deck was fine, clean job, yes i reused head studs, they were 6.2" long and in the service manual it said it's ok to reused head studs as long as they don't exceed 6.23" in length. :/
When I rebuilt my sr I reused the head studs because like you said they were in spec but I was having the same problem as you. I ended up ordering arp studs. Anything that is torque to yield should be replaced. I know that feel, order the new studs and grab a mls gasket while you're at it and install it just be clean about your work
#6 | |
![]() Join Date: Jul 2005
Your surface prep, what was it like? And where is it leaking? into the cylinders air or coolant? I've never had a head gasket failure, and I always do the same thing. Straight edge, razor blade + brake cleaner, FSM proceedure. A couple of times with cometic HG I have used copper gasket spray with good results. But not when I use an OEM gasket. |
