![]() Join Date: May 2010
Trader Rating: (18)
S13/CA/SR Garage Cleanup
Hello again, Zilvians. Summer break is here and tis the season for cleaning/clearing. Just have a a lot of parts from my 240 days cluttering up my house, and I need to make room for B-Chassis parts. Also, This is pretty much all I have left other than little bits, so you can ask if I have something, but not much chance that I do.
Contact Info: Name: Zane Email (paypal): [email protected] Location: Nebraska Shipping: Yes, on most things. I drive frequently to Minnesota, and I could drive within 3 hours from Omaha. Phone: 402-215-8440 S13 1. Front Door Speaker Cowls has some extra screw holes but worked fine- $23 shipped for both 2. Rear seat belt brackets- $8 shipped both 3. Front seat rail trim (Driver/Passenger)- both for $21 shipped/ each $14 shipped 4. Front seat recliner handles (Driver/Passenger)-Both for $14 shipped/ Each $8 shipped 5. Rear seatbelt anchors- $9.00 shipped 6. Coupe Map/Dome light-$12.00 shipped 7. Auto trans shift plate- $5 shipped 8. Wiper cowls- $10 + shipping 9.Sunvisors (Driver/Passenger)- Both $20.00 shipped/ Each $12.00 Shipped 10. Trunk Carpet- A bit dirty, but should clean up well enough- $15.00+shipping 11. OEM Rear floormats (Driver/Passenger)-both $24 shipped/ each $13.00 shipped 12. Various under dash control boxes-Tell me what you need 13. B-pillar covers (faded, but decent condition)- $18.00 shipped for both 14. Front seat bolt covers (Driver/Passenger)-$15 shipped for both sets 38. KA24DE water pump pulley- $9.00 shipped 39. KADE alternator pulley- $8.00 shipped 40. Driveshaft carrier bearing (bracket)- $15.00 shipped CA18 16. Auto Trans dust plate/trans-block sandwich plate- $Free 17. Coolant Lines/Metal manifold pipes- $9.00 shipped each 18. Metal AAC valve hardpipe-$8.00 shipped 19. Random heater/vacuum hoses- Tell me what you need 20. Coil pack bracket-$11.00 shipped 21. Ignitor chip Bracket+Bolts- $15.00 shipped 22. Cam gears and hardware- $25.00 shipped for both 23. Intake camshaft- $25.00 shipped 24. Water pump pulley-$12.00 shipped 26. Throttle body + Bolts- $25.00 shipped 27. Valve Covers + hardware-$35.00 shipped 28. Cam gear-head sandwich plate- $14.00 shipped 29. Intake side Tranny brace- $15.00 shipped 30. Oil Block/Cooler- $18.00 shipped 31. Secondary butterfly valve solenoid- $14.00 shipped 32. Throttle position sensor- A spare I had- $16.00 shipped 33. Valve covers- $30+shipping 42. CA18DET cam caps- Alittle dirty, but pulled from my running engine- $30.00 shipped SR20 34. S13 turbo compressor outlet pipe + Bolts- $25.00 shipped 35. Turbo oil line/drain flange and hose- $15.00 shipped 36. O2/dump pipe-$20.00 shipped New/Aftermarket/Special Interest A1. Brown key light ring- Comes with pigtail and green bulb- $10.00 shipped A2. Unorthodox Racing Vacuum Manifold- New. Bought this on NICO from 'EliteGTR' a while back, but never used it. comes with all fittings and mounting bracket. -$27.00 shipped A3. Greddy Water Temp Sensor Adapter- Used. 34mm diameter. Blue 1/8" NPT. - $30 shipped A4: OE KA24DE clutch- New. Bought a few years ago and never used. Comes with pressure plate, clutch disc and pilot tool, I also have a good TO bearing, and stainless braided clutch line if you need them.- $60.00 shipped A4: OEM Maxima Cupholders- Had these for a bit, they are the spring loaded din pocket type (see pics below). The tray slides perfectly, and the cupholder overlay is in good condition, the tray is just a bit dirty. -$40.00 shipped That should be it for now, I'll add more pictures later. PM/text/email is fine whenever and I'll try to respond within 12 hours. If you would like more than one thing I'll of course do a bit of a price drop. Thanks, Nox
1993 240sx- Parting out 2004 Spec V & 1993 NX2000- Daily 1&2 Last edited by Noxy; 05-25-2014 at 09:16 PM.. Reason: Added cup holders and pics |
#3 | |
Trader Rating: (18)
And for anyone else who could be interested. The friction disc is an Exedy, and the pressure plate is Valeo (?). The parts warehouse I worked at had a brand called Rhinopac and is an OE brand that generally makes kits using various brands for the different parts (I chose the one with an exedy disc). Also, it was mounted, but the engine ended up getting repurposed before it was driven on. Thus the little bit of lube on the splines
1993 240sx- Parting out 2004 Spec V & 1993 NX2000- Daily 1&2 |
Interested in the ca valve covers for $35 shipped and would you have the house that goes from the intake vc to the intake manifold
Signature image exceeds allowable size. |
Trader Rating: (18)
I do not, but you can use a DSM resistor if you rewire it. Easier to find than a OEM CA18 one. If you decide to go that route, I have the rewiring diagram.
