#91 |
![]() Join Date: Apr 2006
ok so as of now my current problems
1. Need front rotors 2. Tie rods 3. Install my turbo elbow lines manifold ras headgasket 4. Buy injectors 5. Get an alignment 6. Cracked windhield 7. get a tune 8. MORE TRACK TIME
2015 Subaru Outback Overlander - Wagonofdoom |
#92 |
![]() Join Date: Dec 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
i need
paint i hate primer now body work a bigger rad fogs dont work any more rewire my fans leaks (not bad) radio trim shift_boot rear sway bar i just dont have one i have new brimbo rotors and thay been sqeeking since i got them and i dont know why? warped body form a car crash not that bad no horn cuz im too lazy to wire a/c works when the car is moveing and make a loud crazy sound when i stay on one place too long WTF! need a new dash need more tires and money turbo system incomplete |
#93 |
Banned from the Marketplace
riped cv boots
starter just went out battery fell through the engine bay (rusted all the way through!) cat is bad radio is stolen and they gutted my harness up hud died leaky radiator |
#94 |
![]() Join Date: Jan 2003
Creeks and rattles inside the cabin
an EGR that's gonna get nuked if it doesn't start acting right alignment off slightly blown rear shocks (Still feels pretty good though) E-brake needs to be adjusted gas light doesn't work needs tranny mounts needs engine mounts and worst of all only 150 (estimated) hp *Starts bawling* |
#95 |
![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
as of now
horrible alignment, bad front wheel bearing one crack almost across the whole bottom of windshield rust setting in running rich on fuel need to replace headers belts squeeking need to replace seatbelts: lapbelts dont match with female end (bought car with s15 seats) speakers are blown= no music a few dents that run along the rear end of passenger side high beams dont turn on, but if i hold the brake the right light comes on possibly a bad synchro and no money to buy what i need |
#98 |
no door locks
shit is rusty on rocker panels fender well and both rails sometimes doesnt start riding on radials bent front subframe some oil leaking interior mismatched carpet torn seats torn front radatior mount is bent fender not attached have to open truck with a vice grip because the latch broke no radio no a/c ball joints are pretty much blown steering rack is leaky brakes went out last weekend left rear brake pad fell out while backing out crossmember bolts spin in place (fuck my life) only one windshield squirter works one plus is that it makes sparks when i drift mario kart style oh yeah! |
#99 |
![]() Join Date: Nov 2007
bucket seat doesn't have seat padding so it's a pain in the ass (literally) to drive more than 30 minutes
dents in the lower rear section of the rear driver's side quarter panel dent on the passenger side door black mark on the corner of the rear bumper on my 3 month old paintjob water leaks into the trunk paint is scratched on the side of the little lip on the front bumper carpet is stained everywhere trunk release doesn't work brakes squeal like a mo fo even tho i have brand new pads leaking clutch master cylinder - FIXED!!!! no air conditioning small crack in the windshield long 10" crack in the sunroof i lost some of the mounting hardware for the oem spoiler so the sides are held on by zipties but other than all that stuff, mechanically, my 240 runs fine! ![]() |
#101 | |
Inactive Admin
![]() Join Date: Mar 2002
Italics indicate that the problem remains, but the parts needed are sourced. |
#102 |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
I need...
Paint. Install aero. Tint. Cage. I think that's it. |
#104 |
mine needs:
play with tp re-check wiring different ecu bolts on exhaust need to be found and replaced, and the rest taken off and loctite'd dual cam ac stuff rubber shift boot that goes under the actual shift boot. big ass dent from driver rear quarter panel removed lip and side skirts painted rear valences and rims wouldnt hurt either. stupid 240's always need work.
Don't forget to tell your mom, she ran out of eggs this morning! Last edited by C. Senor; 09-05-2008 at 02:12 PM.. Reason: que? |
#106 |
![]() Join Date: Jan 2004
on the Acura:
-two small dings on the passenger fender from hitting a tiny deer -driver side corner light sticking out at a funny angle, needs to be bolted in properly -tiny rust bubble forming on rear passenger wheel well (honda rust) -ABS unit leaks, need to buy a junkyard one for about a hundred bucks shipped -as of yesterday, front left woofer makes crazy noise on occasion. didn't do it at all today, who knows the fix: i'm going to knock out the rust, go over it with touchup paint, reattach the corner light properly, maybe fix the ABS, maybe just top it off, and sell the fucker. i plan to be driving a police interceptor this winter. on the 240: -shit's fucked the fix: ignore it
#107 |
Frame is all dented
Spray paint chassis I think its time for another diff Missing some interior pieces ghetto ass sunroof plug worn bushings here and there I think thats about it. |
#108 |
![]() Join Date: Oct 2007
Bad Fuel Pump
Old Dirty Ass Fuel Filter Worn Out Injectors Bad Distributor and wires Old Ass Spark Plugs Fucked Radiator Old Ass cracking Lines Everywhere Worn Brake Pads, Metal On Metal Is More Effective Pretty Much Stock Suspension Exhaust Leak Fan Shroud Broken Clutch Fan Shredded Clutch As Soft As Butter Bushings Need Replaced BAAAAAAD Probably forgetting a few other things. At least it's pretty.
#109 |
salvaged
hit from the right so the whole front is shifted so i got gaps in between the headlights/corner lights and the bumper bad driverside window motor dents and scratches faded bumper cracked dash bought it like this for 4800 ![]() thats what i get for not being patient and wanting my first 96 240sx |
#110 |
![]() Join Date: Jul 2007
nothing is really "fucked"
but I have a list of things I want to do roll/pull fenders get an alignment wait for s15 hlsd to come put 4.63 gearing into that install differential on car buy or make evo brackets buy 300zx 1 1/16th bmc install evo brakes front and rear after that? do a tune up to keep things running well
#111 | |
#114 |
loving this thread here i go.
1. paint. 2. aero 3. wheels. 4.seats. 5. 5 lug 6. diff. 7. cage 8. cracked windshield. 9. replace exhaust. 10. ka mani. 11. dp. 12. boost controller. 13. injectors. 14. safc. 15. harness. and thenn ill be happy now am ![]() |
#115 |
S14
-Fading Paint -Leaky Brake Caliper -Bent brake hardline -Clean title, but i discovered the car had subframe damage after i bought it ![]() -leaky power steering -wheel rubbing on drivers side due to damaged subframe (it seems it shifted about an inch to the left. one side looks super flush and the other side looks sunken w/ 17x9.5 +15 ![]() oh the joys of a used car... s13 -sqeaky brake pads -leaky transmission -oil leak in motor -broken fan shrowd -damaged clutch fan -blown manifold gasket -blown exhaust gaskets -holes in exhaust -salvaged -needs new radiator core support -headlight motors dont work -damage on all fenders -damaged hood oh the joys of drift damage... my s13 doesnt bug me as much cuz all the damage was caused by myself unlike my s14 that has a clean title but subframe damage @(#*@#
![]() D-Street.net | bcuison.wordpress.com |
#117 |
![]() Join Date: Nov 2005
huge dent on driver rear quarter panel
driver brick fog light shudders and goes out on every bump on the road and there are alot w/coils EGR idle f's up every 3 months. CEL is still on, finally took out the bulb, haha 2 years still no paint job, except for my own awesome spray paint job. painted interior needs updating on parts 1 wheel lug missing on both sides, driver side lug missing has a broken wheel stud sold my qr wheel setup and do not feel like buying another. ipod wire keeps fading out on one side thumping undercarriage noise that went away on passenger side front bald tires all around rest is awesome for how old it is
#118 |
Dent in passenger fender, driver quarter panel (huge)
no antenna missing sunroof latch no side mark signals shitty single cam flip ups wont stay up without lights cracked dash trashed up rear, sideskirts aero front 4 lug hub wont hold studs just minor stuff but its still annoying. |
#119 |
![]() Join Date: Jun 2007
On the bimmer:
Headliners all fucked up Door panals are blistered all to hell moonroof motor is blown, cover for the motor access is broken (oops lol) my drivers side sun visor is in my bedroom my wheels have no centercaps my BMW emblem on the hood is upside down dents and dings broken fog light broken grills and its slow.
BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
#120 |
![]() Join Date: Sep 2005
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
Tons of crap...
My car only had a few issues before my five speed swap:
over heated(air in cooling system) random electrical issues to include -door thinks its open if I go around a hard right hand corner -radio turns off sometimes if I hit a bump -gauge cluster lights would not come on every once in a while -if my lights were closed and turned on they do not always pop up automaticly These are the new things that are wrong with it after my five speed swap: brake lights are not working reverse lights are not working still have cooling issues after new alum. radiator And last but not least....(drum roll) my car will not rev over 3.5k But I still love it ![]()
![]() Do you suffer from vaginal dryness... |
