#31 |
![]() Join Date: Jul 2007
Got my under dash support bar back from the blaster, primed and ready for paint:
And the paint to be used...Truck bed liner ftw! And the final product: Just the start of the mission: No More Rust Ever Again! |
#32 |
I finished my 350z climate control mold today to replace the old style lever controls, I was going to use the S14 digital climate controls but the complexity of the 350z wiring and incompatibility of the controls forces me to use these. I could probably get the S14 controls to work, but this is just plain easier and I like how the 350z controls look.
Started out with the two trim pieces, obviously the S14 trim on the left and the 350z on the right. Roughly cut to fit and glued into place, all the while being careful to keep all mounting tabs in place. Molded and sanded smooth ready for paint: Painted with the texture back on, truck bed liner ftw! The final product ![]() |
#33 |
![]() Join Date: Oct 2006
damn dude, this thread is cool. i'm looking forward for more process of your work. GOOD JOB.
#35 |
Finished my 350z/240sx hybrid column today. I landed a new used column off ebay for $15! I opted to combine the two columns because I needed to change out the lock cylinders for the nats security and I wanted the look and the feel of the newer multi controls and the newer keys lol.
Columns side by side (S14 up top 350z on bottom obviously): Columns would have swapped out almost perfectly if it wasnt for the ends being way different: So after comparing and planning I decided to combine the two to make one... Removed the locks for comparison: Test fit of the 350z lock on the 240sx column: Found out that due to the different shapes of the slots the locks fit into the 350z lock did not sit flush into the 240sx slot. 240sx one is round like so: 350z is oblonged like so: But no problem, got out the drill with a metal file bit and went to town and got the lock to seat right: Now I needed to change the mounting plates for the multi controls in order to use the newer 350z type controls, these are actually controls out of an altima, the reason I used them is because they have a switch for the fog lights that I will hook up to control my factory S15 fogs. Here is a picture of them to compare (S14 left 350z right): As you can see the 350z plate is alot larger, but the S14 steering shaft is fatter, so I busted out the grinder took some measurements, made my marks and went to work grinding the welds off to free the plate. End result: In order to get the 350z plate to fit onto the S14 column the hole in the center needed to be bigger, no sweat. I got out a hole saw some screws and a piece of wood to do the deed. My trick, anytime I want to widen a hole in metal, either to make the circular hole bigger or just to turn a hole that is not circular into a clean circle, is to screw a piece of wood to the back side of the metal and use the wood to keep my drill straight to make a nice clean, circular hole. I did this like so: After the hole was drilled I lined my bracket up with my marks I put on the column, went down to my buddies house and had him weld it back into place for me. Re-installed the lock cylinder with new shear screws from the $tealer$hip and here is the final product: And the test fit with the new multi controls: Steering column.............CHECK! ![]() |
#37 |
Dude this thread looked a lot like my S14 build, minus the S15 front and VQ nonsense, but you're doing a much better job documenting everything. Are you going to keep your fuse box? If so, did you take any notes on which wires out of the body harness to keep?
#42 | |
Thanks for all the compliments guys! |
#43 |
![]() Join Date: Jan 2008
very nice project i wouldent have the patience to do such a build and document it all like you are oustanding.
again i wish you the best of luck and hopefully you have no Problems or setbacks in the future! Franco |
#46 |
This is the most refreshing thread that I have opened in months in the chat section. Congratulations on actually making a worthwhile build thread that is breaking newish ground and has inspired custom work. Thank you sir
Florida shut the fuck up. |
#47 |
![]() Join Date: Apr 2003
I totally agree with midnight zenki this is one of the best build threads so far that I have read. Just for the sheer fact that you stepping into uncharted territories with combining different nissan model components into your interior. I really like the altima controls and the 350Z HVAC controls. Makes me wonder wahts next! +349573495743 To you my friend for being so adventurous.
![]() UGR.....SOMETHING WICKED THIS WAY COMES.... |
#49 | ||
#51 |
Ok so I bought this black leather covered steering wheel from a 05 Maxima off ebay for $25.00, to go along with my newer theme, going to make all the controls on the wheel work too.
As you can see it comes with no air bag, well I looked up pricing for a used, unactivated air bag and the price starts around $400. So I was like hell-to-the-NO! Especially since I am not putting air bags in this car and I was planning to gut the air bag out. So I went to the local bone yard and got a deployed air bag center for free and went to work. Here is how it looked when I got it: Removed the air bag and the exploeded device thing: What was left: Used super glue to temporarly hold everything back in place while the good stuff ( gorilla glue ) did the permanent bonding and held it all in place with tape for the facial reconstruction: The result: Put the metal frame back in for the next step: Filled her up with light weight expanding great stuff to support it (god I love that stuff) Prepped for some filling and smoothing: Smoothing it over to hide the creases and cracks from the air bag deployment: All sanded and ready for final covering: Black leather to do the deed and match the steering wheel: Stretching the leather for the clean look: The result: And the final touch to complete the new silvia feel: Lots more to come! |
#54 |
![]() Join Date: Mar 2008
Nice fabrication very creative
![]() How much did it run you to have the dash support blasted? Mine is rusted as hell too it would probably take me hours to do it myself |
#55 |
![]() Join Date: Oct 2007
Great work bro, very creative work! Keep it up. + 1 for you
www.tannermunsondrifting.com |
#56 | ||
#57 |
Haha Drty, it's refreshing, isn't it? Great job with that steering wheel ~
#58 | |
Yeah I know I am going to get that comment quite often, but to each his own, but I also think it goes along with the newer feel I am giving this car. As far as my first thread being locked Ill admit I was a pissed and I even bitched at ThatGuy through PMs a little, but then I read some other hey look at me threads and I realized what the reason for the lock was. Thanks for all the compliments guys. |
#59 |
I'll be watching this thread for wiring up the vq also, I'm attempting the same thing and I'm starting to agree with you its probably easier to use all the wiring from the z instead of trying to make the stock s13 stuff work, plus it gives a classic car that new car feel
#60 | |
