![]() Join Date: Mar 2007
I need to see some pics or examples of how a 4 point harness
bolts up with no roll bar. I installed my Sabelt harness last night and my left shoulder strap(sitting in seat) is really lose Do I need to cross em?Please post usefull pics or links and don't give me a hard time cause Im already pissed that I couldn't figure it out. I bolted it up the right strap to where the stock rear lap belt goes and the left to where the the stock rear seatbelt goes but is has too much slack. Please help ![]()
there should be a sleeve near where it bolts down to where you can adjust the belt to be shorter or longer.. you should be able to adjust the length individualy on the belts.. thats how my Schroth harness are but i have a roll bar.
www.massimopower.com PH: 1(951)402-5386 EM:[email protected] Special Thanks To: www.aeperformance.com www.domospeed.com/blog For Their Continued Support |
![]() Join Date: Aug 2006
tahts waht i did when i had no cage.. you HAVE to cross them. and you will have a lot of slack in the back. then you just adjust. use eye bolts in where the rear seat belts are. and then you are set
100% agree with that...
AFC #1
![]() Join Date: Oct 2003
![]() Not a prudy picture when you roll/roof collapses.
#8 | |
Imma try and see what happens. Oh and im not doing any driving to where I have to worry about a rollover but should I ![]()
