Old 07-06-2011, 10:05 PM   #1
jspec240
jspec240's Avatar
jspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfectionjspec240 is close to perfection
Turbo intake housing removal question
Can u remove the bolts from the back of a turbo intake housing to adjust for adequate fittment to intercooler and intake lines with out messing with the balancing of the shaft?
DREW
SLIDE TO SIDE WORLD WIDE
Feedback!! #/f/showthread.php?t=182673
661 sliders Gymkhana @ buttonwillow
#/f/south-western-st...-sessions.html
>> Bakersfield Hook up thread <<
jspec240 is offline   Reply With Quote
Old 07-06-2011, 10:14 PM   #2
s13silvia123
s13silvia123's Avatar
you should be able to adjust it. there should be a C clip between the housing and the center section.
take pics so i can figure it out for you. i've done it a few times with few different turbos i've had.
Old 07-06-2011, 10:20 PM   #3
jspec240
jspec240's Avatar
Well I loosened the bolts and it rotated around the center housing. I'll get pics in a min. But still not sure if that would throw the balance off. Thanks man.
DREW
Old 07-06-2011, 10:34 PM   #4
s13silvia123
no it won't throw off the balance unless mess with the turbine shaft.
Old 07-07-2011, 12:21 PM   #5
jspec240
jspec240's Avatar
Thats the answer I was lookin for. I took it off and was careful to not let the fins hit the side wall of the inlet. when people check for shaft play wont it actually mess with the balance even more?
DREW
Old 07-10-2011, 12:56 PM   #6
s14unimog
s14unimog's Avatar
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Send a message via AIM to s14unimog
the impeller doesn't care how the compressor housing is clocked.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
