![]() Join Date: Sep 2006
TPS wiring for S13 Manual & Automatic Trans
I have an S13 1990 5 speed and the TPS wires are Black, red-green, and a 2 wire greyish white wire. There is a silver wire around the inner wire like a coaxial cable. What is the silver outside wire for because the TPS only uses 3 wires. Was the 4 wire setup for the automatic trans? Do I need the 4th silver wire?
#2 | |
![]() Join Date: Jan 2009
An automatic TPS uses 6 wires. |
1990 s13 tps
1990 SOHC TPS Wiring? I have a broken plug with 2 yellow wires. I got another plug with 3 wires-2 yellow and a green/black wire. But my harness only has 2 yellow wires coming into it.
I have a 5 speed manual. Do I need 3 wires? There is a green/black in the harness but it goes to the sensor along with a black and a white wire--total 3. If you need to see a photo.......I can post one. |
That looks to me like a automatic tps. you should only need three wires, ground, power and signal.
-the light green/red stripe wire is your tps power -the white one is your signal -the black is your ground check the wires with a volt meter does the car run? |
Wiring
I have 2 yellow wires that are in the plug which I have been using for 8 years like that.
The wiring manual shows the 3rd pin is a dotted line going to the ECU. |
![]() Join Date: Dec 2004
Question. In doing a 5speed swap, does the motor still need to use a Auto TPS or Manual? I'm getting code 43 (TPS sensor) from mine. I've tried replacing the TPS, but the CEL still stays on.
