![]() Join Date: Jun 2010
Chase Bays LS1/LS6 and LS2/LS3 Engine Harnesses
Chase Bays LS1/LS6 Engine Harness Prices CM1 - $699.99 CM2 - $999.99 CM Mil-Spec - $1,399.00 ![]() Chase Bays LS2/LS3 Engine Harness Prices CM1 - $799.99 CM2 - $1,049.99 CM Mil-Spec - $1449.99 ![]() Made with brand new PLUGS, WIRE, and PINS NO SOLDERS ENGINE HARNESS REPLACEMENT, does not include headlight, taillight, or fusebox portions. Loomed with Nylon Sleeving and Adhesive Glue Lined Heat shrink Eliminate the risk of your old, used, and worn out engine harness failing when you need it most! (IE: On the track, out in the boonies, rush hour traffic, a crime scene) Help eliminate some chassis wiring on your race car, Tuck your engine harness, simplify your wiring Harness routes straight to PCM like stock with outputs mentioned on plug list Optional Mil Spec connector for the firewall Completely redesigned/reinvented Chevrolet LS engine harness that fits perfectly and rocks a stealthy look If you have any questions let me know. Thanks, -Logan [email protected] 205-623-2188 ext.1 Add us on Facebook Welcome to Facebook - Log In, Sign Up or Learn More
![]() IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE www.ChaseBays.com | [email protected] | (205)623-2188 |
Morning Bump to the Top!!
Bump to the Top!!
![]() Join Date: Oct 2006
Trader Rating: (163)
Just so you know it's pointless to bump threads in the advertiser forums. It will not move the thread to the top. Threads stay in the order they were originally posted. Kind of sucks, but then again you don't have vendors bumping them every day fighting for the top spot. Carry on
Yeah, true. TTT gets old.
