![]() Join Date: Apr 2007
![]() Feedback Score: 20 reviews
Garage clean up time...S13 and S14 content inside
I have accumalated alot of parts over the years of owning s-chassis's and so I went throw the stuff and here are some parts that I don't forsee me using anymore so they are up for sale.
Parts are located in San Jose, CA. Norcal I will ship any of these items at the buyers expense. 1: Stock S14 SR20det intake manifold with throttle body and aftermarket throttle wheel. -$150 2: Freddy (Greddy Style) Intake manifold for the S14 SR20det. -$150 3: OEM JDM Nismo strut bar. A little beat up and missing 2 bolts and nuts but can easily be replaced. -$100 4: Unknow brake master cylinder head shield -$25 5:SARD oil catch can -$100 6: S14 SR20det wire harness with Z32 maf/pigtail and Apexi cone filter -$200 7: S14 SR20det power steering pump -$100 8: S14 SR20det coil packs (4) -$150 9: S14 SR20det Head with almost new valves, springs and retainers -$150 10: RS-R SR20det down pipe -$150 11: S14 JDM tension rods with brake cooling panels -$100 12: JDM Jasma certified, don't know brand, full cat back exhaust with custom flex-pipe cat. There are the usual scratches but the tip is a little banged up. The tip part is actually just riveted on so you can remove and rivet on a new one if you want. -$450 13: Skyline front brake calipers and rotors. I believe they are the ones off the R33 or R34, correct me if I am wrong. Comes with all the parts, pads, clips, retainers, and so on. Will also include full set of stainless steel lines. -$700 14: Wedge engineering bottom mount seat rail -$100 15: S14 Rear C-Pillar bar -$80 16: Willans 3-point seatbelt harness (Black) -$100 17: Blitz LM type-r racing radiator with Blitz radiator cap and flex-a-lite e-fans. -$900 18: S14 JDM front tension rods with brake cooling ducts -$100 19: S14 stock front and rear sway bars -$80 20: S14 Base model door panels ( means the insert are just gray ) -$100 for the pair 21: S14 Zenki driverside window switches -$25 22: NRG S13/14 short hub -SOLD 23: NA Ecu -$150 24: AEM ram air intake kit -$120 25: S13 SR20det oem fan shroud -$80 26: Freddy ( Greddy Style ) S14 rear expanded diff cooler cover SOLD 27: M's Racing height adjustable shift knob -$25 28: S14 rear trunk lid in pearl white. Has holes drilled in there from stock SE wing and Navan wing. Otherwise a pretty straight trunk. -$50 29: Complete set of good condition Zenki tail lights -$80 30: Pair of perfect condition OEM Zenki clear corner lights -SOLD 31: Stock base model S14 passenger seat. Does not recline but slides back and forth -$60 32: S14 coolant over flow bottle. Good condition, no cracks or holes -$40 Last edited by sokodu; 02-15-2012 at 01:56 PM.. |
