Closed Thread
Old 11-15-2010, 12:16 PM   #1
Chase Bays
Chase Bays's Avatar
Chase Bays is an unknown quantity at this point
Chase Bays Brake Line Kit for OEM Master Cylinder/Booster
Gathering some feedback here.
Chase Bays Nissan 240sx Brake Line Relocation Kit for OEM Master Cylinder
Just put up our brake line relocation kit up for OEM Booster/Master cylinder setups. We wanted some feedback on it. Our Brake booster delete kit for S13/S14 incorporates a bulkhead fitting on the firewall, but to our advantage its only one...seen here
If we wanted to do bulkhead fittings with an OEM setup there would be 3 bulkhead fittings very visible, it would be hard to make work with heat installed not to mention gas pedal clearance, and the lines would closer to the exhaust manifold in most applications. We can make anything work but I wanted everyones opinion on if we should offer a bulkhead kit an additional cost ($100+) or just offer the setup we do now.
Thanks for the feedback!
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE
www.ChaseBays.com | [email protected] | (205)623-2188
Chase Bays is offline
Old 11-15-2010, 01:46 PM   #2
Dustxking
Dustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of light
I really like the lines with that OEM Master, looks super clean and not to mention what a pain hardlines can be when needing them out of the way.
Dustxking is offline
Old 11-15-2010, 01:55 PM   #3
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
I like the whole stock BMC setup with the relocation lines too. My hardlines are all messed up. haha.
karl wasabi is offline
Old 11-15-2010, 02:19 PM   #4
thefro526
thefro526's Avatar
I really like this.
Now if I'm not mistaken, this kit replaces just the hard lines and then you tap into the stock soft lines in the front and the stock tee in the rear?
thefro526 is offline
Old 11-15-2010, 03:34 PM   #5
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
Are you guys going to do an ABS brake line kit?
Instagram: @garagelu
garagelu is offline
Old 11-15-2010, 06:29 PM   #6
bboyoracle
bboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to behold
Send a message via AIM to bboyoracle
I am currently running ChaseBays Brake Lines off the stock Master Cylinder (The second option). Definitely a great choice for those who are worried about running booster-less on a street car or don't want to go as extreme (like myself). Also install is effortless can be done in minutes with no drilling or fabrication involved. Really a great kit!
bboyoracle is offline
Old 11-15-2010, 10:16 PM   #7
ROOSEY
ROOSEY is an unknown quantity at this point
^^^^^not to go off topic but....holy engine bay!!!!!! i need to change my pants after seeing that. thats sick man.
ROOSEY is offline
Old 11-16-2010, 10:55 AM   #8
Flicktitty
Flicktitty's Avatar
Originally Posted by thefro526 View Post
I really like this.
yeah, i'm wondering this too?
Flicktitty is offline
Old 11-16-2010, 01:07 PM   #9
bboyoracle
Old 11-16-2010, 01:47 PM   #10
Chase Bays
Chase Bays's Avatar
Thanks for the feedback folks, really appreciate it!
I really like this.
That is correct.
Old 11-16-2010, 01:48 PM   #11
Chase Bays
Chase Bays's Avatar
Thanks for posting this! You need our Power Steering Kit!
Old 11-16-2010, 02:49 PM   #12
Flicktitty
Flicktitty's Avatar
That is correct.
does this include the fittings to go onto the factory lines? or do you just need normal flares?
Old 11-16-2010, 03:19 PM   #13
Chase Bays
Chase Bays's Avatar
It does include the adapters, all you need is tools.
Old 11-16-2010, 04:55 PM   #14
GeneStarWindGSW
GeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant futureGeneStarWindGSW has a brilliant future
Does it work with all type of brake lines (SS & hard line) for Z32/BBK calipers?
GeneStarWindGSW is offline
Old 11-16-2010, 05:05 PM   #15
240sxdriftin
Trader Rating: (25)
Feedback Score: 25 reviews
Definitely like this setup for the stock booster! Looks super clean and gets rid of hardlines! I will be purchasing this setup soon! Along with the power steering setup!!
Keep up the good work Chase Bays!!
IG: @bwagg88
240sxdriftin is offline
Old 11-16-2010, 06:31 PM   #16
Chase Bays
Chase Bays's Avatar
Yes it does.
Thanks!
Closed Thread
