![]() Join Date: Dec 2006
sr20det redtop 62 injector help? (searched)
i took this from my local thread. no luck there yet. so im trying here/
my engine will crank, has spark, but no signal to injectors. so i cant get any gas into my engine. any ideas???? or has anyone ever had this problem. i checked my ground and i should have power to the injector need help thanks also...to make things worse..my fuel pump fuse keeps blowing. i did the christmas light trick on the injector clip...and no signal to light up the light on any of the injectors i used a test light to make sure i was even getting power to my injectors. heres what i found: ecu 101=injector no.1 drive output = light did not turn on ecu 1= coilpack 1 output = light did turn on |
