![]() Join Date: Jun 2009
Sr trans dumped gear oil
I took my S14 for a drive came home parked later on i came out and saw a puddle of gear oil. Took a look under the car and I see a steady drop of oil coming from under the driver seat from the trans. What would cause this? Trans is old and abused btw
Sent from my D6616 using Tapatalk
WTB: S14 Wiper motor and S15 HLSD w/ Shafts It's always broken!
#2 | |
![]() Join Date: Jul 2005
Usually they will splash gear oil all over the place when the shifter hole becomes exposed. Take apart your shifter trim and seal it up. |
#3 | |
I'm sure the oil was splashed everywhere while your car was moving, then it dripped on the driveway while it was at a stop. Put the rubber boot on your shifter. Also, clean oil and other debris and look for cracks or the source of the leak with the car running.
My SR20VET |
I had a similar issue. I fashioned a round seal that goes around the shifter handle, made from high temperature rubber hose (intended to support 800psi and several hundred * F).
