Old 03-08-2014, 01:01 PM   #1
FourtyKid
FourtyKid's Avatar
FourtyKid is an unknown quantity at this point
VH45 swap still won't start
I tried starting the car yesterday with no luck after installing an ignition coil relay... but I think I had the throttle set too low so no air was getting into the engine. I gave it about 25% throttle while cranking and it fired twice but didn't start. My battery is pretty much shot now after cranking on it for months without it starting.
I am freaking out wondering why this thing won't start. It should be simple, I've seen people have theirs running while it's still hanging from a damn cherry picker and yet mine won't start.
I've checked the ECU, only code was #54, No communication from Automatic Transmission (obviously)...I am just lost on this.
@s13cole
FourtyKid is offline   Reply With Quote
Old 03-08-2014, 02:16 PM   #2
wildnerj
wildnerj is an unknown quantity at this point
did you ever checked if its getting fuel some ppl actually make mistake by putting pressure line on the return of the fuel rail
wildnerj is offline   Reply With Quote
Old 03-08-2014, 02:44 PM   #3
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
#/f/showthread.php?t=549436
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 03-08-2014, 02:44 PM   #4
tacobellman_2007
tacobellman_2007's Avatar
tacobellman_2007 will become famous soon enoughtacobellman_2007 will become famous soon enoughtacobellman_2007 will become famous soon enough
So what you mean is that it won't keep running? Or...?
When my friend started his VH45DE, he opened the throttle a bit and sprayed either carb cleaner or starter fluid into it and we let it run for about 3-5 seconds, opening and closing the throttle to let air in of course. Sounded great.
You should probably make sure your voltage readings on the battery are good of course. If not, buy a new battery for it. My friend has been using his daily S13 battery whenever he test starts his VH45 lol
Amateur photography by me
tacobellman_2007 is offline   Reply With Quote
Old 03-08-2014, 02:57 PM   #5
FourtyKid
FourtyKid's Avatar
I mean I heard two loud bangs (no headers or exhaust so any firing is going to be incredibly loud inside a small shop) and exhaust smoke came drifting up from the exhaust ports. So it fired twice but didn't fire again.
Did you do this without the intake pipe/MAF on it? Or spray it into the MAF?
@s13cole
Old 03-08-2014, 03:18 PM   #6
tacobellman_2007
Hmm interesting. My friend's more of an expert on this stuff so I'm not sure how okay or bad exhaust smoke coming up is...I think when we started his up once, smoke came out too, but I can't remember if it was exhaust or what.
The MAF was still on, but the pipe was off. He sprayed into the MAF.
Most recent vid:
http://www.youtube.com/watch?v=mM3SfOJjdZ0
Old 03-08-2014, 03:39 PM   #7
FourtyKid
FourtyKid's Avatar
I think there's a very good possibility that my plugs are fouled from gas. I'm going to pick up some new ones monday.
Also, your friend has his CAS set waaayy advanced doesn't he? It's at 90 degrees advanced when I see most people's sticking straight up and down.
@s13cole
Old 03-08-2014, 04:47 PM   #8
Chaluska
Chaluska is an unknown quantity at this point
did you hook up the fuel lines properly?
Chaluska is offline   Reply With Quote
Old 03-08-2014, 05:01 PM   #9
FourtyKid
FourtyKid's Avatar
They should be set up correctly. The hardline that is farther to the passenger sideon the car has the fuel filter on it and is set to the front-most hardline on the VH. Return is the other. I took the line off the filter and gas shoots out when the pump primes so it should be correct.
@s13cole
Old 03-08-2014, 05:29 PM   #10
Gar9854
Gar9854 is an unknown quantity at this point
I hate to beat a dead horse but when I was cranking my sr for the first time my lines were reversed and it stumbled once or twice then nothing for days.. just try to flip them around and see if anything changed
Gar9854 is offline   Reply With Quote
Old 03-08-2014, 05:43 PM   #11
FourtyKid
FourtyKid's Avatar
Tested them, I had them correct.
@s13cole
Old 03-11-2014, 06:39 PM   #12
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
Check to make sure you dont have a rag or something in your intake manifold and check all of your grounds.
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 03-11-2014, 07:30 PM   #13
Trap Star
Trap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant future
Send a message via AIM to Trap Star
S13 or s14?
Was your car a manual to begin with?
What ECU are you using?
More info makes it a lot easier for people to help you.
86 300zx/90 240sx/97 240sx/96 LS400/03 350z
-Shake N' Break Racing-
Trap Star is offline   Reply With Quote
Old 03-11-2014, 07:33 PM   #14
FourtyKid
FourtyKid's Avatar
It's an S13, manual from the factory. Stock Q45 ECU.
I've found that my timing has jumped a couple of teeth so that's why it won't start. I'm pulling it out of the car to fix it and do some other work on it.
@s13cole
