ok i blew my hg changing to a metal cometic and puttin BC 264 cams in it i have a safcII and a wideband how much boost can i run safeley without having to worry about timing or spark and possibley blowing my motor i dont know much about this just something one of my friends mentioned and i want to be safe
safcII stock bottom end cometic head gasket Brian crower 264 cams fmic wideband thats all i just want to know whats the safe amount of boost cause i had the car on 15 before and it was fine but the electic fan stopped working in traffic and the car overheated and blew the head gasket im running 8lbs now just to be safe but i want to know if i can go higher
![]() Join Date: May 2005
put the stock oem clutch fan back in with the shroud.
Stock T28 can do 17psi (it did on my friends) Assuming you have all the supporting mods i.e fuel pump,fmic,etc 8psi is weak city I would run 1 bar on a daily setup. (I did'nt really need even more) And like I said about 17psi for the more spirited driving. |
