![]() Join Date: Apr 2008
SR20det does not rev past 4k
Hey guys,
I have a fully built sr20 tuned with a AEM v2 and map sensor. It starts up and revs fine until it hits 4k and backfires and will not rev past 4k. Zero boost leaks as I tested it. Any ideas would be appreciated or if you are super familiar with AEM and want to read my data log. Again AEM v2 with a map sensor. Thanks |
![]() Join Date: Nov 2010
Have you checked the coil packs ? Boost leak test ? What about your plug gap and heat range ?
Typically failing coils will fire under light load and breakup badly once you start to get under more load
How much boost? I remember with stock coil packs, my engine worked better with the copper plugs. As soon as I switched to the ls style coil packs, I switched to iridium plugs and those worked better.
