![]() Join Date: Nov 2007
Alternator or battery?? help!
so, yesterday i took a hard turn and my battery light w/ a clicking noise from under the dash came on... one of my buddies says its a bad alternator and i wont get far driving w/ it... but i drove bout 15 miles and its fine, car didnt die didnt even show any signs of change. (the funny thing is. is when i get on the gas the clicking noise and the battery light on the cluster go off) my other buddy said its a loose connection on the alternator... im not sure what it could be... anybody have the same problem? any kinda help is great, thanks guys!
![]() Join Date: Nov 2008
only way to know is to have your battery and alternator tested. most places test both for free. make sure the alternator is at least putting out 14.00v and 30+amps. as for the battery. how long have you had it? is it tied down? is it a maintenance free battery or a liquid/fillable battery. I have been working with batteries for a long time so any question you have just ask.
![]() Join Date: Sep 2003
or not.
sounds like a loose connection. only way to find out is to get down there and check. if you went around a turn...the autoparts store's machine can tell you if its a loose connection. have it checked. BEFORE you go buying shit you dont need to |
![]() Join Date: Dec 2002
I'm at a loss for words on this one.
#8 | |
Hey hey hey, I just figured out it wasn't spinning after I made this thread... So I've obviously found my problem. |
if you wanna check to see if the alternator is bad, then leave the car running, then disconnect the battery. if the car still runs, the alternator is good. if not, then its bad.
if you wanna test the battery, use a multimeter. |
