Old 03-24-2002, 11:09 AM   #1
AZN GTR
AZN GTR is an unknown quantity at this point
Instead of plugging into the cigrette lighter, I want to just hook up the wires, but the problem is, how should I make it so that the wire isn't hanging on the dash?  Anyone did this before please tell me how you did it.
AZN GTR is offline   Reply With Quote
Old 03-24-2002, 11:52 AM   #2
gschroeder78
gschroeder78 is an unknown quantity at this point
Send a message via Yahoo to gschroeder78
I've never done this but I would imagine there is a hot and a ground lead. Just connect the hot lead to an ignition/accesory wire and then ground the other. If it works right, it should only come on when the car is on.
Oops, I guess that wasn't your question.
To answer your question, depending on how long the wire is or where you locate it, I would say that you could run it behind the dashboard probably a PITA but would look clean.
1989 240SX Coupe
-Eibach Prokit Springs
-KYB AGX Struts
-Apex-i N1 Dual Exhaust
Westminster, CO
gschroeder78 is offline   Reply With Quote
Old 03-24-2002, 11:54 AM   #3
yenpit
yenpit is an unknown quantity at this point
"hard wiring" like u said is an option, but another option is to buy an accessory socket.....just like a cig lighter, but no element, and hard wire that. u can mount it up under ur dash so u can't see any wiring. this gives u a hidden socket and ur stock cig lighter in its orig place, and u don't have to cut the plug off the radar detector (that way u can use it in other vehicles). just an idea <img src="#/f/iB_html/non-cgi/emoticons/satisfied.gif" border="0" valign="absmiddle" alt=':satisfied:'>
'98 240SX 5spd[br]http://www.speedwisemotorsports.com
yenpit is offline   Reply With Quote
Old 03-24-2002, 02:34 PM   #4
toddnappi
toddnappi's Avatar
toddnappi is an unknown quantity at this point
Send a message via AIM to toddnappi
Hi,
I just did this the other day with my V1. I needed some extra wire but I picked it up at Pep Boys - I think it was either 16 or 18 (probably 18) gauge. I unscrewed the sun visors and pulled out the a-pillar (there is one screw) and ran the positive and ground behind them. Then I ran them down in the door seal (you can still see them) and through a small hole which leads right behind the kickpanel. My whole dash was already out so I just ran it under and connected it to the cigarette lighter. My central ground for everything is the emergency brake. Any more ?s, feel free to ask.
toddnappi is offline   Reply With Quote
Old 03-24-2002, 04:56 PM   #5
my240likenoother
my240likenoother is an unknown quantity at this point
Send a message via Yahoo to my240likenoother
all you have to do is run the wire across the headliner down the piller to the fuse box and pick ne one of the fuses on the right side of the fuse box and put the + wire around one of the prongs on the fuse and plug it back in and ground the - wire
and just stuff the raidar dector up in the headliner like i did (in the pix) useing the window mount with the suction cups.
now when you turn on the car it will turn on and when you turn the car off it will also turn off <img src="#/f/iB_html/non-cgi/emoticons/hehe.gif" border="0" valign="absmiddle" alt=':hehe:'> <img src="#/f/iB_html/non-cgi/emoticons/hehe.gif" border="0" valign="absmiddle" alt=':hehe:'>
my240likenoother is offline   Reply With Quote
Old 03-24-2002, 05:12 PM   #6
AZN GTR
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (my240likenoother @ Mar. 24 2002,5:56)</td></tr><tr><td id="QUOTE">all you have to do is run the wire across the headliner down the piller to the fuse box and pick ne one of the fuses on the right side of the fuse box and put the + wire around one of the prongs on the fuse and plug it back in and ground the - wire
</td></tr></table><span id='postcolor'>
awesome That's exactly what I'll do
