Hey guys! So im a long time lurker here on Zilvia, and finally decided on making a build thread.
1990 CA18DET GReedy EManage Ultimate S14 T28BB TOMEI Cams TOMEI FPR EXAS High Flow catalyst Trust Exhaust Trust FMIC HKS EVC R35 AFM BNR32 Injectors BNR32 Fuel pump Koyo Rad Fortune Auto Coilovers Nismo control arms Cusco 1.5 LSD Work CR Kai Z32 Rear Calipers S15 Spec R Front calipers Shaft Masters 1 piece driveshaft This has been a longtime coming and im finally at a point in my life where i can start building her the way I want. I got my car when I was stationed in Japan beginning of 2012. ![]() ![]() ![]() ![]() I worked on her almost every weekend. Fixing up everything from coolant lines to replacing window moldings and every little tuneup i can do. She was whored out from two other service members on base before hand, and it showed. ![]() I did my best learning about every little thing about it, usually through trial and error. ![]() ![]() ![]() After 2 years i moved to Phoenix and worked on her when i could. I had it re-tunned and worked on the little bits but i had no time or money for that matter. ![]() ![]() She sat pretty much untouched untill i moved back home here in Seattle ![]() ![]() So now im working on getting the garage set up and also working on the rest of the fleet! 2000 AP1 ![]() 2015 Final Edition Evo X [/url]As of right now, i got a shit ton of parts on the way so i will update when i can! |
![]() Join Date: Jun 2003
Trader Rating: (129)
dang! glad to see someone who is obviously passionate about car life!
also thank you for your service! |
