Old 11-30-2013, 04:01 PM   #1
allforthebenefit
allforthebenefit is an unknown quantity at this point
1.5jz navan s14
Hey guys some of you might know this car. I got it thinking it was a deal and well it wasn't a lot of rust everywhere wasn't taken care of at all. I guess my fault for not really checking it and trusting the old owner, but regardless now it will be bigger better faster stronger haha. I wish I had more engine bay pics of when I took out the sr20 but sadly I don't. The car will be built and tuned in house at Gonzy tuning. A lot of the supra guys might know him and his work.
Parts:
2jz bottom end
1jz head port and polished
Arp head studs
Tt head gasket
Bc springs and retainers
Bc 264 cams
Big daddy performance fuel rail
1000cc precision injectors
Aero motive fuel pressure regulator
I will be going e85 so everything will be e85 ready
Mega squirt ms3
Freed engineering motor mount brackets
Freed engineering driveshaft
Strii fuel, boost and oil pressure gauges
Freed engineering shifter extension
R154 transmission
Act clutch
My cluster will be all led (will post pics)
I will be changing my rack and pinion its f 'Ed up
All the wheel bearings are gone
A lot of front suspension will be changed
Innovative 72mm turbo
I will keep you guys updated. I appreciate your time looking if you have any questions feel free to ask.
This is how the car used to look
This is the sr20 that was in it sadly like I said I didn't really take much images of the engine bay. Let's just say it was horrible.
Taking out the sr20 out with the old. Lol
Passenger side rust :/
Driver side rust yes I know it's horrible!
Sr20 out of the picture time to take things apart
Found a nice 240 to take the rocker arms out. Hard at work!
Nice cut. A lot less rust barely any just surface
I got a lot of pics but I'll just start here a lot of work done a lot of things taken out and a lot of rust fixed! As far as engine bay goes I'll post more later
The setup that will be going in the car just gotta change oil pan and do the springs retainers and cams.
allforthebenefit is offline   Reply With Quote
Old 12-22-2013, 11:09 PM   #2
allforthebenefit
More work getting done
Old 12-22-2013, 11:10 PM   #3
allforthebenefit
Some work got done epoxy primer needs wet sanding then another coat of primer. Then paint
Old 12-23-2013, 06:15 AM   #4
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Nice. Subbed..
BiG MiKE86 is offline   Reply With Quote
Old 12-23-2013, 08:02 AM   #5
stroked_jz
stroked_jz is an unknown quantity at this point
why megasquirt... that thing is garbage...
stroked_jz is offline   Reply With Quote
Old 12-23-2013, 10:36 AM   #6
allforthebenefit
Everyone has there own opinion. I actually am the tuner so I would love your input as to why you say it's garbage. Many say the same about aem.
Old 12-23-2013, 12:33 PM   #7
stroked_jz
more or less what a few of my friends have said. i only know 1 guy out of the 3 of them who actually got a megasquirt set up working on a jz.
Old 12-23-2013, 03:33 PM   #8
allforthebenefit
Its a bit difficult to set up considering you have to wire everything up yourself. And it's different then setting up a aem or any of the newer standalones, but it has great features more then most standalones. The ve tuning makes up for wiring everything up yourself. I'm not saying your wrong everyone has there good and bad reviews but you won't be disappointed with my setup . Haha
Old 12-23-2013, 03:37 PM   #9
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
What's the advantage of using the 1JZ head on the 2JZ block? Looks like a promising build! Keep it up!
Frank_Jaeger is offline   Reply With Quote
Old 12-23-2013, 09:09 PM   #10
Kioes
Kioes is an unknown quantity at this point
Essentially the 1j head flows a bit better, the 2j head for example has a bit more restriction around 5th and 6th cylinder due to casting shapes and the 1j also has slightly bigger exhaust valves (yet 2j's intake valves are slightly bigger) but you also gain slightly higher compression and 500cc more displacement using the 1j head on the 2j block apparently.
That info is bassed on stock heads though, which realistically are still good for large power.
Kioes is offline   Reply With Quote
Old 12-23-2013, 09:35 PM   #11
silviaks2nr
silviaks2nr's Avatar
ge or gte block?
Old 12-23-2013, 09:38 PM   #12
Kioes
I'd assume GTE as he said nothing about having to tap the oil return,
Old 12-23-2013, 11:19 PM   #13
allforthebenefit
Sorry guys it's a vvti ge block. Yes I want to
Push the rods to see what they can do. .
Old 12-23-2013, 11:32 PM   #14
Kioes
going for the slightly higher compression?
Old 12-24-2013, 12:06 AM   #15
allforthebenefit
Right just slightly higher. See what it can do. I have to put pics up of the head being cleaned up port and polished and springs retainers and cams being put in. I also have pics of the oil pan being switched from rear sump to front sump. Bare with me as I have to upload them. Soon enough .
Old 12-24-2013, 12:32 AM   #16
Kioes
Did you go bigger intake valves to get the best of both worlds? (Example, 1j head already having bigger exhaust valves then 2J)
Old 12-24-2013, 10:03 AM   #17
juvi22003
juvi22003 is an unknown quantity at this point
Coming along nicely love what you did with the engine bay....
juvi22003 is offline   Reply With Quote
Old 12-24-2013, 04:35 PM   #18
allforthebenefit
No Im still going to used stock valves but that I'd a really good idea!
Old 12-24-2013, 04:36 PM   #19
allforthebenefit
Thank you I appreciate the compliment!
Old 12-27-2013, 09:37 PM   #20
redhatchy92
redhatchy92's Avatar
redhatchy92 is an unknown quantity at this point
Too bad this car wasnt what we expected it to be when we bought it. it looked so nice from pics but when we started to take it apart it was obvious that it needed much work. its gonna be a beast when its done regardless and you know its gonna be built right and Gonzy's.
to be faster you have to slow down
WTB OEM SILVIA AERO SKIRTS!!!!!! PM ME
redhatchy92 is offline   Reply With Quote
Old 12-29-2013, 11:25 PM   #21
allforthebenefit
Hey guys so since we can't paint because it's too cold I decided to get some work done on the motor......
This is the rear sump oil pan that was on
Spent hours cleaning the front sump. Now minty! Lol
Other side of front sump
Putting the sealant on!
Tourqeing things down!
Old 12-29-2013, 11:34 PM   #22
allforthebenefit
How the motor looks! Not bad!
The front sump baffle plate almost done!
Finished all clean!
All done till next time lol
Old 12-31-2013, 10:47 PM   #23
allforthebenefit
Hey guys more of an update we got to do more work in the garage!
Engine bay came out really awesome just how I wanted it!!
It changes color from green to light blue like a teal it's crazy really beautiful color!
Old 01-01-2014, 03:15 PM   #24
Kioes
Coming along nicely mate!
Old 05-06-2014, 06:11 PM   #25
allforthebenefit
Hey guys so I been a little busy lately haven't been able to work on car, finally made some time so time for work here are some updated!!!!
So I ordered wheels
Left are rears right are fronts I like them a lot!!!
Started taking out the cams!!
Installing bc springs and retainers and 264 cams
We did the freed engineering extension for the shifter came out great!
Took at the rack horrible condition sending it to get rebuilt!
Oh look it's bent lol
Took out wheel bearing because they are shot
Decided to go q45 calibers with brand new rotors and pads
New hubs
Rebuilt rack with circuit sport inner and outter tie rods
That's all for now will keep you updated very soon trying to get the ball rolling
Old 05-07-2014, 02:16 PM   #26
mxkilla450
mxkilla450's Avatar
mxkilla450 is an unknown quantity at this point
what wheels are those?
So you think my car is to loud?Let my gate play a song for my people...
mxkilla450 is offline   Reply With Quote
Old 05-15-2014, 08:33 AM   #27
allforthebenefit
They are yoshiharas
Here's an update.... Just got the silly sway bar removed the stock one thank god lol
Brakes are all done!! Just have to order braided lines.
Custom brake lines being test fitted for the brake master cylinder!
Hopefully next step is dropping in the motor.
Old 06-07-2014, 09:12 PM   #28
allforthebenefit
Motor before being dropped in I also decided to take off exhaust mani and intake mani so nothing gets scratched and we can see where mounts go
It's night time but motor is in! Now to get valve covers turbo inlet powder coated hmmm what color.still a lot of work left but a good sign of what's to come.
Old 06-26-2014, 05:56 PM   #29
allforthebenefit
Hey guys a little bit of an update. Might have to relocate the fuse box
Put in the sway bar! Now just waiting on some fuel and some powder coating! Still don't know what colors I'm going with! Lol
Old 06-26-2014, 08:31 PM   #30
FourtyKid
FourtyKid's Avatar
FourtyKid is an unknown quantity at this point
Nice build but beware I've heard nothing but bad things about Circuit Sports tie rods.
@s13cole
FourtyKid is offline   Reply With Quote
