![]() Join Date: Sep 2006
Trader Rating: (30)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 30 reviews
Valve Cover Details...
I was just wondering about this little T on my valve cover(S13 blacktop). There is a tube from my intake to the T to my catch can...then I would think that little hose under the catch can goes to the oil pan or somthing.
The reason I bring this up is to ask what should I do if I can't fit my catch can there anymore? I just installed a new exhaust manifold and I can't fit my catch can there anymore. I've seen some people put little filters on the T...but I wanted to make sure. Should I just plug up the hose that used to go to the bottom of the catch can? And should I just take off the tube from my intake to the T and plug that up, leaving the T open? On a side note- Is it okay for my valve cover to leak oil kinda a lot around the head? I think it's probably just the valve cover gasket...but to double check I ask Zilvia .Any help would be appreciated...I wanna make sure my car is safe to drive without oil shooting everywhere. ![]() |
![]() Join Date: Apr 2003
for now, run the front of the tee to the intake, and the back of the tee to the return tube on the engine *where your stock catch can was at*
get a aftermarket can and run the lines properly, problem solved ![]()
