Prev Previous Post   Next Post Next
Old 09-19-2017, 03:52 PM   #1
boostin_jim
boostin_jim is an unknown quantity at this point
s13 Sr20det help!!!!
I have a 89 hatch rhd swap with a sr20 I pulled the motor to freshen it up at first when i put it back together an hooked up the battery it buzzed with the battery hooked up ignition off an had a weak power at the pump when turned to on position so i went through the fuses, relays an grounds an now there's nothing to the egi relay an pump buzzing stopped i bought a pre owned ecu aswell thinking that was a issue nope.... an the egi pump relay has no power.. some please help i just want my car back on the road even if there's ways around it to get it back running
boostin_jim is offline   Reply With Quote
