like the title says i have a small problem, plz dont flame me...i did search and found some things that might help and tried them with no avail
so any help will be appreciated ![]() things that might help you help me: nearly stock ka24de with -intake -secondary butterfly delete -cat-back exhaust -msd blaster ss -new ngk iridiums -new ngk wires -new cap and rotor -new ignition coil wire -throttle body spacer -working egr -connected aiv -fuel filter replaced about 5k ago -s13 auto ecu on stock manual s13. -stock injectors [email protected] ohms [email protected] ohms [email protected] ohms [email protected] problems: -at start car is very hesitant and doesnt want to go, but doesnt misfire...just kinda bogs down until about 2500rpm (cold start). -after it starts going car seems to run well under load. -while decelerating with very partial throttle (ie. to slow the car down but not too fast) in gear car misfires -at ~2000 rpm (while decelerating in gear) misfires several times and car gets a lil jerky. -in neutral and revving up car will occasionally misfire after 2k -under full throttle no misfire is noticed -gas mileage has dropped from ~26 to ~24mpg (due to the auto ecu i presume) -starts up fine even when cold thank you zilvians for your help ahead of time! |
i just replaced the o2 a couple months ago (May i think)...could it be dead already? Thanks
