Hey guys, i am going to pick up a z32 MAFs (out of the car), is there a way i can check the working condition of it, like resistance? Thanks for the inputs.
![]() Join Date: Jun 2004
Trader Rating: (73)
Put a voltmeter to it.
Touch the terminals and if the MAF is good you'll get a 12v signal that goes smoothly through the MAFs prongs.
Trader Rating: (73)
Set the voltmeter to 12v...
It's been a long time since I've used a voltmeter, but the voltmeter will send out it's own 12v, and it will pass through the prongs.
Trader Rating: (73)
No, that's how I tested it off the car, you can make your voltmeter create a 12v constant.
![]() Join Date: Mar 2007
Trader Rating: (31)
Hmm...I wanna test my N60 Maf too.
So does the "blow into the Screen and the voltage should change" Still apply even not in the car??
z-tERty-2 |
