SR20 idle issues
Let me start off by saying, I have researched high and low and found plenty of threads describing my same issue, none of which ever get updated and I've tried everything suggested to no avail.
The setup:
The problem is my SR has idled really high for quite some. So I finally did the following below and now my issue seems worse. On a cold start the idle will hunt for a few seconds then stabilize at 1600rpm and will stay that way even when it gets up to temp. If I rev it while idling or drive it at all after that it will start hunting/surging and the idle will jump from 1600-2000rpm rhythmically. I can get it to stabilize if I'm in gear and get the clutch just to the engagement point. The wideband shows a solid 10 until I drive it and it starts surging at which point it does lean out when the idle drops. I'm also getting code 34 for the knock sensor which wasn't an issue before.
That was everything that was done to solve the high idle issue initially. The following is what I've done to troubleshoot this new issue
Other things worth noting
I may have tried some other things that I might be forgetting. But I'm looking for suggestions on what else I can do. I'm about to put a feeler out on my local FB group to find someone with a spare MAF and ECU I can try, but if anyone sees this and is in the west Houston area let me know if you have ones I can try. Last edited by frsh2fourty; 02-14-2017 at 03:09 PM.. |
The injectors were flow tested/rebuilt by a local company around July or August of last year so the o-rings weren't even on my radar tbh.
I did pull the rail off when I removed the manifold to clean the IACV but didn't pull the injectors from the rail so I suppose the grommets could be shot, though they looked fine on inspection before I reassembled everything and didn't appear to be leaking. I suppose it wouldn't hurt to go ahead and replace them as I don't think I ever have...but is there a way to definitively identify that as the issue without just replacing them? |
This is a common problem with non-recirculated BOVs.
NismotronicSA - Speed-Density Tuning for Nissans |
People have mentioned that in some of the threads I've found, and I suppose that could be why the idle is high, but it doesn't explain the surging as I've had the swap in the car for something like 4 years with the BOV venting to atmosphere and its never done that. I'm not trying to argue against your suggestion, just trying to better understand the issue.
#6 | |
![]() Join Date: Jun 2005
Don't use Brake Cleaner or a Cigarette... Get a propane torch and turn the gas on. Move it all over the BOV & even stick the end of the torch right into the BOV exit to force propane in & see if the idle changes. Lack of re-circulation was never an issue for me. Idled fine as long as the damn BOV closed & sealed properly.
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 | |
The BOV did come with the swap and I have no idea how long the PO had it before that so it could just be pretty old. It would be super odd if it just happened to fail completely right after I fixed the other stuff though. |
#8 | |
![]() Join Date: Dec 2006
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
Skimming through your list, it sounds like you've exhausted all of the potential vacuum leaks. This may be silly, but worth a shot at checking the ignition timing, spark plugs, fuel pump (adding a relay will help stabilize the voltage). Hope this helps.
#9 | |
I did the fuel pump relay around the time I did the swap. Plugs looked okay before the event this past weekend but I'm sure they are due to be changed after thrashing the car at the drift event this past weekend running as rich as it was. |
So just to update since I finally got a chance to work on the car...
I tried the propane method to test for vacuum leaks including the BOV which didn't seem to show anything. I finally broke down and bought a new IACV and installed it yesterday. That seemed to fix the surging idle but idle still won't go below 1600 RPM when warm with the idle screw closed completely and wideband gauge reads about 11.0 so its still running pretty rich. I'm going to make a boost leak tester and try that sometime this week and I'll update again after that. |
Check your spark plugs and gap them to .032 to .029.
I had a similar issue and the causality was a bad O2 sensor and the wrong plugs gaped incorrectly. I'd try the cheap stuff before you get into changing the more expensive stuff. |
Also there is a set screw on the throttle body. It might have moved and holding the throttle plate open. Also check the throttle cable and make sure it is not holding the plate open
Sent from my SAMSUNG-SM-G930A using Tapatalk |
Update time because I hate searching for problems and finding a thread with a similar issue where OP never posts the resolution...
First wanted to say thanks to the guys offering suggestions. So Martin from RS Enthalpy did a local dyno day in town last week and I decided after testing and replacing everything I could think of it was time to see if a tune would help or at least pinpoint the problem. The tune was something I've been wanting to do for a while but didn't want to give him a broken car and waste both our time. Prior to the dyno day he told me to send him my ecu so he could install his chip with a base tune. For some reason I got curious when boxing it up and decided to open it just to check things out. It never crossed my mind to do this when trying to track down my idle issue because I assumed if the car started and ran the ecu had to be fine. Well I came to find out that the ecu already had an m377-1 multi board chip installed. So basically the entire 7 years I've had this swap, its been running on some random tune that the guy I bought it from never told me about. I guess whatever it was tuned for didn't come with the swap but it didn't make enough of a difference to really hinder the cars drivability. With Martins base tune the car idled smooth right around 8-900rpm and we got it tuned on stock fuel pressure, timing, and boost to make around 230hp which is exactly where I wanted the car to be. tl;dr: rich condition and high idle were due to a random tune I didn't know I had. |
