![]() Join Date: Jun 2003
I'd like to know too. Additionally, I'm looking for stock spec S13 pistons in a 1mm overbore. Supposedly you could get them from a dealership but they've been out of stock for some time.
Well you can always piece together your own?
I read your other thread and you are looking to make 320rwhp IIRC At that point you'll want at least forged pistons which can be had anywhere in a variety of sizes. FRSport sells a timing chain kit ACL/Clevite sell bearings ARP sells hardware Felpro makes gasket sets. Etc. |
![]() Join Date: Nov 2009
Trader Rating: (35)
![]() Feedback Score: 35 reviews
Im currently rebuilding my Ka24de
you can get the rebuild gasket set at the nismo shop for around $170 The Nismo Shop : West Covina Nissan : KA24DE Gasket Kit the timing chain assembly at FRsport for $180 OSK 13028-53F02 KA24DE DOHC Timing Chain Kit 1991-1998 Nissan 240SX I just ordered my set, all i need is piston rings, Metal HG and bearings... and im set... |
#9 | |
![]() Join Date: Apr 2010
91-94 Nissan 240SX 2.4 Master Engine Rebuild Kit KA24DE | eBay |
#11 | |
![]() Join Date: Dec 2002
I'm thinking forged pistons and nothing fancy beyond that. Would be nice if i could buy it all in one place at a small discount.. These look sketchy as hell. 380 for everything? I'll pass. You can guinea pig it.
I used a ebay npr rebuild kit before. i used them on a honda gsr motor and one on my sr20det. I drove my s13 for almost 9 thousand miles with no problem, no smoke, and still had great compression. I even turned up the boost to 10psi after the break in. It's probably still alive. (sold it)
So im fine with npr, but if you have the money go with oem. |
#14 | |
as well as being able to measure critical tolerances the kits did the job couple of those KAs blew up but due to other factors and a few are still running strong a few years after irrc reason we tried them was because we were experimenting with high compression KAs and 248 cams and SOHC pistons were a bit hard to come by just providing some first hand experience having said that, I'd buy/recommend oem for most of my parts |
Well yes I completely agree with all of you. My mind was just like wtf! why so cheap? I'm sure the products are good but I just want something that's gonna last me and know won't break.
#16 | |
Fel -pro gasket kit OSK timing kit supertech 8.6 pistons .20 over reconditioned treated stock rods All sep hardware Clevite main bearings (acl was on national backorder) acl rod bearings Rebuilt head |
![]() Join Date: Aug 2004
![]() ![]() Feedback Score: 6 reviews
As far as felpro head gaskets, the Felpro Permatorque unit has been known to hold 40 psi of boost on 4G63 engines. Not sure what it can do for the KA.
Regardless, what kind of rebuild parts are you looking for ? I have mulitple accounts with almost all the top companies for internals so PM me with a list of parts and I can get you ideas on pricing and what parts you can get. I can get MLS, ACL, Clevite, Supertech, Arias, Wiseco, Eagle, JE, Crower, etc. |
#19 |
Trader Rating: (35)
thanks for offer but i pretty much got everything i need, im just looking for a good metal HG for my ka.... other than that, rings are easy to find... Ima end up using King Racing Bearings... my goal is to build a stock Ka with a few aftermarket mods to hold at least 10lbs of boost... Aiming for a sleeper Ka-T....
#20 | |
#22 | |
few ka-t members using it with 500-600whp
![]() built ka-t |
#25 |
I'm going to be running around 15psi
I have an enthalpy tune. Good on you. I'mma just copy your engine build. ![]() How much was it, and what kind of machine work did you do?
#26 |
![]() Join Date: Dec 2005
Might as well do forged internals if you are going to rebuild, why waste time machining and doing all the work to put OE replacement parts in???
#27 | |
![]() Join Date: Feb 2004
he said he was going with forged pistons, you dont need upgraded rods for what hes wanting.
#28 | |
![]() Join Date: Nov 2005
****IF ANYONE NEEDS A SET UP OEM KA24DE PISTONS AND RINGS BRAND NEW AND SOME SUPERTECH VALVE SEALS PM ME I HAVE SETS OF BOTH FOR SALE!****
#29 |
I checked at a dealership yesterday and they're discontinued. I should be ok with stock replacements from beck/arnley or something.
#30 | |
Polished crank hot tanked bored. O2 over rings fit hone reconditioned rods wrist pins pressed in decked |
