![]() Join Date: Aug 2013
S13 sr20det vac lines- Will this work, if not then why? (Mucho searcho)
After many searches, on multiple forums, over the last 3 days and reading the FSM finding what I thought was what would work but I am confused and stuck.
Many "vac line" threads are dead ends (w/dead links and pictures) or "oh, never mind I fixed it (and no solution is posted)" or they don't include all the components below. The FSM is nice for factory setup, but useless to me for this set up. I feel like this is a very common setup and hopefully a solution will come and someone can use this in the future! Heres the run down: S13 Redtop Isis Manual Boost Controller (has one in and 3 "outs") Boost Gauge No Emissions Canister CX Racing "Greddy" style BOV Stock T25 My free time is limited, so I will be hooking up the vac lines and hopefully will be able to start it up by turkey day, so bare with me... Word version: FPR to Upper, Smaller, Left Throttle Body Vacuum in. WasteGate to MBC "in" MBC "out #1" to Upper, Larger, Right Throttle Body Vacuum in. MBC "out #2" to cabin Boost Gauge. BOV vacuum line to Lower, Left Throttle Body Vacuum. Here's the Picture: ![]() So, almighty engine wizards, can someone confirm or offer a solution to this setup? Thanks!
![]() Join Date: Aug 2011
That is the improper set-up!
The upper right nipple goes to BOV, you can tee off this also for the boost gauge. The bottom left is to be capped off. You need to make a nipple fitting on your intercooler pipe, (hot pipe preferably). The. You have you're MBC in between the actuator, and hot pipe fitting (boost source). Make a boost source! |
#3 | |
Upper left to FPR Upper right to BOV & T'd to the BG MBC from WG to nipple on hot pipe? Is there a particular reason to cap the lower left nipple? Edit: also, is there a reason why I can't read boost from the MBC?
The lower left is used for charcoal canister. Since you don't have one, its not needed. Just cap it off.
That lower left nipple is not a boost source, you cannot use it like one. |
