Old 05-14-2008, 10:07 PM   #1
tercel drifter
tercel drifter is an unknown quantity at this point
exhaust manifold asap
the far right stud on the exhaust manifold is broken. i do not know how long it has been like that. My turbo is now out of the engine bay and i would like to know is it worth trying running it 7 out of 8 studs? I have already tried to remove it, ill try once more i guess.
thanks ,
alex
tercel drifter is offline   Reply With Quote
Old 05-14-2008, 10:11 PM   #2
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
nope, you should use all 8 so you dont have any leaks. a small leak will ruin the gasket and you'll have to end up pulling that shit out again to put another gasket on. just take it out/drill or whatever you need to do. Don't take any shortcuts
SoguRacing is offline   Reply With Quote
Old 05-14-2008, 10:47 PM   #3
Sileighty_85
Sileighty_85's Avatar
I had the same shit happen to me same stud too
had a nasty leak too
I had to use a 90* drill and use an easy out,
Enjuku had stronger studs, I bought'em, no more problems and looks good
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
