Old 08-31-2010, 08:41 AM   #1
kcon
kcon is an unknown quantity at this point
Question s14 sagging doors
Hi Everyone
Been looking for a while about s14 sagging doors and found a lot of info about the s13 door hinges but not much about the s14. Just wanted to know if there is a pin and bushing kit or do i need to grab new hinges. Thanks i also checked mounting location under fenders and it is not rotten.
Thanks
kcon is offline   Reply With Quote
Old 08-31-2010, 08:45 AM   #2
projectRDM
projectRDM's Avatar
Replacement hinges are easy to install but you might just loosen the hinges first behind the fender, lift the door a little, and retighten. The doors sag from people using it as a 'crutch' to get in and out, my driver door sagged a little and just a little tweaking by putting a floor jack under it with the hinges loosened was all it needed.
FORMERLY R240NA
Old 08-31-2010, 09:06 AM   #3
kcon
Great didn't even think of that just been reading about pins and bushings and replacement hinges. I will definitely try this and hopefully all is cured
Thanks for the quick response i will be trying in the next couple of days.
Old 08-31-2010, 04:17 PM   #4
dt-p88
dt-p88 is an unknown quantity at this point
my s14 has this problem, hopefully its that easy to fix good to know thanks.
dt-p88 is offline   Reply With Quote
Old 09-01-2010, 09:30 PM   #5
NightSlider
NightSlider is an unknown quantity at this point
have this problem slightly but haven't had the focus to fix it. thanks for reminding me.
Shift_Chirp
NightSlider is offline   Reply With Quote
Old 09-02-2010, 12:52 AM   #6
nyc240sx
nyc240sx's Avatar
nyc240sx is an unknown quantity at this point
Got a quote from fontananissanparts. Com 150 for all 4 hinges new for s14 for both doors it's a good deal
nyc240sx is offline   Reply With Quote
Old 09-02-2010, 07:15 AM   #7
kcon
$150 that is really reasonable. I am gonna try to give the doors a lifting on the weekend and if this does not work just gonna order four new ones. Would be nice if it just needed a readjustment.
Old 09-07-2010, 03:23 PM   #8
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
Hit the junkyard up and get those hinges and done...you won't be spending a ridiculous amount there, grease them/or WD-40 and you'll be straight....
S14Serge is offline   Reply With Quote
Old 09-07-2010, 04:55 PM   #9
projectRDM
projectRDM's Avatar
Unless the salvage hinges are equally as bad, then you've wasted time and money.
Adjust the door. If that doesn't help, buy NEW hinges. Also, WD40 is not good to use on hinges, use lithium grease.
FORMERLY R240NA
