Rerouting Chassis Harness S13 questions
First off I searched and couldn't answer my question.
So my chasis harness got a little chewed up from being lowered. Fixed it. Now I tried rerouting it above little lip and I got that done. I go to put my fenders back on and they will not fit, and I tried everything! Is there a trick to getting them on? Do i need to bend my fenders? Would front wider fenders (supermade etc) fix this with less of a hassle? Thanks for any advice. |
Okay just follow the wires to the cockpit then un plug the huge connector and reroute the load of wires from the engine bay then Underneath the fender back to the cockpit and plug it back
Some cutting of that triangle hole near the fire wall is required
looking to buy ka24de gaguge cluster |
#9 | |
i did the same! pretty simple task. but takes time.
![]() Join Date: Aug 2007
I cut the casing/tape and shit off the wires, so they are just bare wires. Then electrical tape em real tight and tuck that bish up there. Throw a coupe zip ties on it and your good to go. You probably have it too far up, that's why the fender wont go on. If you have it right, then fender will still be tight but it will line up with the holes.
