![]() Join Date: Apr 2012
KA24DE white smoke
okay so yesterday i noticed my 240 was spittin some white smoke (very little) so i took out the spark plugs to check them and noticed the number 2 plug was wet with oil, cylinders 1 & 3 also had signs of a little oil but no wet plug and cylinder 4 was fine. From what Ive researched Ive learned that it may be the gasket for the valve cover leaking causing oil to go into the cylinders. Im going to do a pressure test soon hopefully its not my rings or anything. And the car runs fine so i dont think its a head gasket.
Always has anyone had this problem or know what it might be? car only has 148k miles. any help is highly appreciated! ![]() |
i need this part right? http://www.oreillyauto.com/site/c/de...word=pcv+valve
Usually white smoke would be the sign of burning water. Most would say its the head gasket but...I had the same problem today and noted that my car was leaking oil so I'm kinda not thinking its the head gasket because I just changed it. Pcv valve sounds cool.
Posted from Zilvia.net App for Android |
If it was coolant i doubt id have oil in my cylinders lol im pretty sure after looking more up on pcv valve that it is my problem, ordered a new one for 2 bucks thanks to a Oriellys discount (;
I recently fail smog with my 93 240sx for gross polluted. My s13 have alot of white smoke coming from the exhaust tail pipe. i decided to change head gasket, valve seal, fuel filter, o2 sensor, new spark plug, air fliter, clean my egr, intake gasket, header gasket, valve cover gasket, new water pump, new termostat, new tps,clean my iacv, ect.. pretty much the whole head gasket set kit.. with that being said...i still have white smoke and car smell like its burnig to much gas...did compression test and all cylinder have 155 psi...any suggestions and help i would really appreciate it.
