![]() Join Date: Dec 2008
Trader Rating: (54)
![]() Feedback Score: 54 reviews
Selling my brand new Rb25 Exedy twin plate clutch. Comes with brand new oem nissan 14mm sleeve and throw out bearing. Both parts are needed for Exedy twin plate. Asking 1,500 firm for everything.
Part number NM32SD Specs Number of Discs Twin Spring Damper Discs Sprung Center Disc Push Type Disc Outer Diameter 200mm Spline Teeth / Major Diameter 24T / 25.6 mm Willing to trade for Rb26 valve covers plus cash Defi gauges boost,oil pres,water tem plus cash lmk (951)479-6414 Flywheel For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of our multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application. |
[QUOTE=ariansworld;4713751]
QUOTE] will this work on a any other flywheel/clutch setup? i bouught my trans with no sleeve or tob...lmk if ur willing to sell seperate thanx |
#10 | |
Trader Rating: (54)
[QUOTE=sexcii-zenki;4718226]
Only on twin plate clutches since the bearing and sleeve are shorter then stock. I have the stock ones still, sleeve and bearing. Just pay shipping and you can have it. |
