#92 |
#93 |
Can I see some clear images of the the S14 Rear Calipers? I'm interested if the bleeder screws are not rusted in and the piston boot/seals doesn't need to be replaced.
Shipping to 21703. Thank you |
#94 | |
Thanks |
#104 |
![]() Join Date: May 2012
Looks like it's a factory security system keyless car. Do you have the matched set of Keyless Remote, and the Smart Entrance Control Unit? Maybe even two remotes? Thanks.
#105 |
Sorry it had an aftermarket alarm installed. I might still have the control unit but not the remotes.
#107 |
#108 |
Cool, I'll get it then.
The part number on the unit should read 28595-70F10. If so - and you can find it I'll take it just to have a spare. Still need a fob tho...anyway, just PM me your PPID and I'll get you funded, and post up your feedback profile. - Teddy
#109 |
#113 |
#118 |
ITEMS STILL AVAILABLE
-Trunk -Front and rear seats (fronts missing rails) -Sunroof glass -Zenki tail lights -Rear interior panels -Rear seat belts -Rear subframe -Front subframe -Front and rear sway bars w/ bracket -Steering wheel w/ airbag -Passenger airbag -Glove box without lock/latch -Center console w/ armrest -Rear parcel/speaker shelf -Dome light -Map light w/ sunroof switch -Some stock suspension arms |
#120 |
$60 for the trunk. Since you're far away I can't imagine shipping to be cheap and the chance of getting damaged is pretty high. I shipped door panels about a month back to Virginia and it was $85ish. Same size box the trunk would be going into.
