Hello everybody, I'm currently stuck on my rebuild because I can't figure this thing out.
the following oil pump assembly is from a 1997 rps13 blacktop type X SR20DET
this is how i disassembled it for cleaning.
1x plunger
2x springs
1x screw
there is no oil seal washer (which would lower the oil pressure)and the plunger looks different from the ones that I see on the net.
I double checked with motoiq's oil pump rebuild and frsport's assembly "set" and they all look different to mine.
Those also have a small relief hole in the middle of the plunger. Mine doesn't have one
I'm pretty sure no one has played with this one before because there were no marks on the screws whatsoever.
Can anyone please help me out with his. I dunno if I should just get a new set or put it back together.
Also I'm thinking maybe this has been revised with the later models just like the strainers have been for instance.
This is driving me crazy
