As the title says, every few minutes while driving at medium ram's on the highway, my s13 makes a very loud sound, that is identical to air blasting out of a compressor gun. At first it sounded like it may be coming from my rear left coilover, but that wouldn't make much sense, and I have no sagging or oil leaking from the CO.
Since then, the sound seems to be coming from the engine bay, around the left side. Car is a N/A Ka24e, all stock, all brand new vacuum hoses,new fan clutch. Any ideas would be helpful, I can't find anything online about this. |
![]() Join Date: Dec 2004
Trader Rating: (58)
Is there anyway to take a video of the sound? It really could be literally anything.
I tried, but you couldn't hear it from inside the car over the exhaust. It only happens while driving at around 70mph though. It wouldn't be a coilover though, right? Probably a dumb question, but just want affirmation on that. Lol
No rubbing, I do have fender liners but those look to be in perfect condition. Will do though. I have a blacktop on order right now, this sound is just freaking me out. Hahaha
![]() Join Date: Mar 2009
you said "air blasting out of a compressor gun" do you mean one that just blows air, or did you mean a impact wrench? I would assume you mean just the sound of air hissing out of some where. I would go back over all your vacuum lines and make sure none have came off anywhere. also check you egr tub for cracks or breaks. Last thing would be to check the intake manifold gasket. Spray WD-40 on each runner where it meets the head. The engine will idle up if there is a leak.
I had a KA24E that had a sound of air. It was a bad intake manifold gasket.
Do you need; Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill S13 Silvia J's, Q's, K's, A's Bumper grill inserts. Male Plugs for S15 headlights PM me if you need them. |
Any luck figuring it out?
| ka24e, s13, stock |
