just basically completed my first sr swap but have been having a problem with my gauge cluster for like a month the car was a sohc witch i knew the tach wouldnt work so i ordered what i thought was a JDM cluster but im gonna assume i got screwed because nothing worked on that cluster, i had everything on my sohc cluster but the speedo & tach. today i put in a cluster from a dohc and everything worked ( dont know about speedo but had a tach) it worked than i went drive around my neighborhood and before i even got outta the drive way everything stopped working. im pretty positive i shorted something out (like a dumb ass) i dont have any interior in my car and the cluster was just temp. supported by zip ties but it shifted alittle and stopped. i popped the 10A fuse thats labeled meters or gauges i think but once i replaced it nothing changed so im curious maybe theres another fuse somewhere or something i can check before i return the dohc cluster to the junkyard for a new one, they gave me a 90 day warrenty on it so it wouldnt be the end of the world if i ruined it.
but this whole problem is getting really annoying so any help would be sick.
