Banned from the Marketplace
Brake Rotor Help
Just did a 5 lug swap on my s13 convertible.
Now, the s13 verts have slightly larger brakes up front because of the added weight. They do not have an abs module but the brake caliper is the same as abs models because they are larger. What I neeed help with is finding the right rotors. S14 abs rotors are slightly too small and the brake pads overlap, 300zx rotors are too wide and do not fit. Any other rotors I can try? Such as a maxima or something? Thanks! |
| 5lug, abs, brakes, pads, rotors |
