| Private Sellers Provide your experiences with individuals here. No flaming, accusations, or complaints! Be fair and objective. Make it info you'd like to see before you make a purchase. |
Did I get jipped?
Years ago, I bought a fidanza flywheel and spec clutch from a guy on the forum and I finally decided to install it because I am also installing a head gasket and the bolts are super easy to get to. Anyways, I was trying to put the flywheel on, but it just wouldnt slide on smoothly. I tried the old one and with a little wiggle, it went on smooth.
The etching on the front of the flywheel is NIS13 6848. I cant find anything on the internet to reference it against. I'm pretty sure that I got taken advantage of, I just wanted to see if anyone has seen this before and can hopefully clarify |
![]() Join Date: Jun 2003
Trader Rating: (129)
Gee. Thanks for providing zero information for us to help you determine if it's the right part of not.
- is it the same size as your old one? - have you contacted the manufacturer to see if they can help determine if it's the right part? |
