ISR 5 lug hubs + rear z32 setup?
I have a s13 4 lug wanting to switch over to 5 lug.
I have an entire z32 brake conversion i want to install also, ive heard you need to use na z32 rear hubs or s14 5 lug hubs. Are the ISR(isis) 5 lug hub conversions compatible with running a full rear z32 brake setup? Rear brake setup: z32 rear calipers/rotors z32 ebrake Assembly R33 ebrake lines. Please help! I searched alot and want a definitive answer before ordering. |
