Just picked up a s13
hello guys
Just picked up a s13 for $400 but the bad is that is an automatic. Need some help on turning this s13 into a 5speed. How difficult is it to turned it? THANKS |
It's not too hard. It will just take a bit of wrench time and some research. There are some good guides here on Zilvia that outline everything you need to do and all the parts you'll need. Enjuku sells most of the parts new if that's the route you want to go.
![]() Join Date: Dec 2010
I am actually tackling this this weekend in my s14. I bought all of my parts from enjuku, great people over there. I know it is a little bit different in the s13 but here are two links that I used to get the gist of what needed to be done.
S14 5-Speed Swap 240sx: How To Auto To Manual Swap. - Drift | Drifting | Drift Forums |
#4 | |
![]() Join Date: May 2009
Congrats on the price man. Check out your local junk yards, SJC has to have some near by. If not ebay, FRSPORT, craigslist, enjuku as stated above and craigslist are where i got the remaining little things i needed that the yards dident have.
![]() Join Date: Apr 2010
im sorry to hear this, should have stayed away since your everyone's next victim on here. Everything you've asked has been covered (thousands of times) and you had to do is use the "search" part of Zilvia. Good luck with all the hate your about to get, im just the calm before the storm.
#6 | |
yea we got a few junk yards. thanks for the advise. |
the advise ill checked them out. |
#8 | |
ill be checking the links THANKS AGAIN |
Hey guys, I also just picked up an 89 S13. I've been trying to figure out the one light that is on my dash and it is not labeled it is an orange light and its on the left side of the gauge cluster 5th light from left to right. Would anyone be able to tell me what this is? I am hoping it is not the check engine light if so I may have some work to do.
