#32 | |
![]() Join Date: Feb 2014
Sent from my ONEPLUS A5010 using Tapatalk
#34 |
I had a 91 z32 2+2. I tt swapped it, new nissan wiring harness, all deletes, rebuilt turbos, upgraded to 2nd gen 370cc rb25 injector, tuned, replaced every deal etc while engine was out. Car ran pretty great.
Ultimately sold it awaiting for it to have a random problem where the engine would have to come out again. Great choice going sr, enjoy! |
#35 |
![]() Join Date: Feb 2008
nice build, picking up a 92 2+2 auto for 500 today, same color as yours, I would love to swap an sr20 but looks more than what I can chew lol
9/25/17-'91 Z32 TT '15 WRX-dd |
#36 | |
If this car had been a factory TT, I would have left it alone. Thanks! Its really not that bad, there will be a mount kit available soon, with a stock SR you can get a running SR-Z for quite a bit less than a proper TT swap. My build is me not being able to decide what I really want, so I am just going all out to try and make it the best it can be.
#37 | |
#38 | |
![]() 1) The kit in question hasn't been commissioned for production as of yet. There is another mount adapter circulating on the market currently and utilizes stock mounts (I actually have tb13's old set lol. But there is a good chance I will not be using them). 2) Wiring for all 90s Nissan is pretty much the same. Adapting a SR into a Z is fairly straight forward and you can reuse a majority of the S13 SR harness. Just takes a little time as compared to opening your wallet Lets just say there are a few of these going together with varying levels of prep, mount ideas, turbo setups, etc etc etc ![]() |
#39 | |
As for wiring, like RalliartRsX said, it is very simple. Converting a harness is easy, but you can purchase a new harness from wiring specialties if you wanted to that is plug and play.
#40 |
Suspension is finally all torn out, the amount of spiderwebs under this thing is horrifying
Need to go pickup a press so I can replace bushings then I can slap it all back in with all of the new arms.![]() ![]() I did pickup a Z32 subframe that was modified for an RB swap. Seemed like a good idea at the time, but its pretty damn hacked and I couldn't get it to line up in the car so I'm not sure it I'll be running it... ![]() Didn't get much else done on the Z, but the S13 got a lot more love. My buddy spent basically the whole day stripping the interior and knocking all of the sound deadening out. Not pretty, but its way better than before. ![]() ![]() Tossed back in what we care about and called it "done" for the time being. Already looks 10x better than it did a few weeks ago. ![]() Finally had all of the parts for the SR so we decided to get it in the car. First issue we ran into was the throwout bearing sleeve, the DE uses a much longer sleeve than the DET. Since we put a DET clutch in the motor we needed a DET sleeve to make it all work. Thankfully there was an SR transmission in the trunk of the S13 and it had the correct sleeve we needed. ![]() Nearly killed myself trying to get the SR into the car with my tiny hoist, but we got it after a lot of cussing and hitting shit. Glad its in and we can work to get it running now. I can't figure out what suspension is on this turd, its a fucking monster truck even with a ton of shit in the trunk and the motor in it Don't mind the crash bar, one of my other friends took some of the bolts out and I made the mistake of jumping on it ![]() ![]() ![]() ![]()
#41 |
Its been too damn long since I'd made a real update for this, I've been busy putting this S13 together for my buddy, but I've had some time to mess with the Z and finally have some stuff worth posting.
I have picked up a hacked/boxed subframe years ago from a friends Z that had an RB swapped into it. I hung onto it because I figured I'd end up using it at some point. After trying to install it on my car, I realized it is tweaked and won't fit. Not the end of the world, I wasn't stoked about running it due to how much material had been removed anyway so I notched mine in a more proper way. Still needs to be boxed, but I wanted to make sure I cut enough out before I start adding material back to it. ![]() ![]() I bought another SR because I wanted some extra parts off of it. I knew the motor was fucked when I picked it up, but wasn't sure to what extent. This motor had its oil pressure sensor fall out on the freeway so I was expecting the worst for the bottom end and it did not disappoint. Here is your daily dose of carnage ![]() ![]() \ Using a spare SR block I had, I slapped an oil pan on it and bolted it up to my transmission. Since motor mounts aren't readily available for this swap, I figured having a super light bare block would make everything easier when it comes to making mounts, not to mention being able to just pull the head off will make things easier. It is hilarious how tiny the SR block looks bolted to a VG trans ![]() ![]() ![]() With that bolted up, it was time to set it into my shell and check out how it all fits. Bolted the transmission mount up and supported the motor with a floor jack, everything clears perfectly. So much room for activities in here now, so refreshing to see vs the VG that I am used to working on. Set the extra head I have on it just for shits and giggles, got me so hyped to get this all together! ![]() ![]() ![]() ![]() I've been running a set of 17x9 +15 FN01R-C's on this car forever. Love how they look and the fitment is spot on, but it is time to change things up. I bought a set of TE37 SAGA's late last year and wasn't sure if I'd run them or not. I tried selling them, but had no luck so I said fuck it and bought tires for them. They are 18x10.5 +15 square with a 265/35r18, it'll be a chore to make them fit, but well worth it. The finish, engraving and SAGA face design is incredible. ![]() ![]() Finally have my fuel setup mostly finished up too. I've always hated high port SR's with top feed setups, the fuel rail sits up way too high above the intake and just looks out of place. With a set of ID1050x's and a Radium fuel rail, I can run the injectors without a hat keeping the rail nearly level with the intake manifold when installed. Paired with my Greddy manifold, its not only great looking, but functional. ![]() ![]() Suspension stuff is coming along, slowly. I still need to buy a press to get all of the bushings out, but everything is torn apart and I have all of the new parts in hand ready to go. Also really considering selling all of the GKtech arms I have for the car, my tension rods look like hell after less than a year, most of which the car was just sitting for... I already purchased SPL tension rods to replace them, having ran a bunch of different brand arms, SPL cannot be touched in terms of quality and finish. Now to decided if I spend the cash or to hold off... ![]() ![]() Working on getting motor mounts worked out, I should have my built motor back soon and I will be able to get all of the suspension back on next weekend, shit is going to get interesting soon ![]()
#42 |
Disappointing week over here, found some wonderfully fucked stuff that is going to set me back a bit...
![]() Got bad news about my SR head, previous owner had been running the car incredibly lean and now there are some wonderful cracks/pitting around the plugs. Blows me away that someone would spend the money to fully build a cylinder head then have someone tune it who doesn't know what they are doing... RIP ported/polished S13 SR head ![]() Getting my rear suspension apart went really smooth until it came to getting my axles out of my hubs. The first came with a bit of hammering, no real issue getting it free. The second though, let me fucking tell you, was basically fused inside the wheel bearing. After smashing the tip of the axle, bashing the back of the spindle and applying quite a bit of heat it finally came free, well almost free. Had to bust the angle grinder out to get the axle out, at least it was already clicking so I didn't destroy a good part. ![]() ![]() BUT WAIT! THERE IS MORE! Was getting ready to knock out my subframe bushings when I noticed one of the LCA pickup points is completely fucked. Probably wouldn't really effect much, but I am not going to waste time replacing bushings in a subframe that isn't in good shape. It looks like the LCA has been replaced, so I can only assume the PO of the car had the LCA replaced and they left the subframe in this condition. ![]() Soooo on a more positive note! A local friend came to the rescue with a head for my motor. It really sucks to have to write the first off, but this one keeps me on track for the power/response I am searching for. This head was built by PortFlow in SoCal, its got Supertech dual springs/guides, +1mm Ferrea valves and a really nice port/polish. Perfect candidate to slap on the bottom end that is being built and make some nice power. ![]() ![]() One thing I have been worried about since I bought my turbo manifold was the wastegate placement. Since I have a motor sitting in the car, I figured I'd see how it fits. Thankfully, it fits great! The wastegate fits right under the BMC and easily clears all of the brake lines. Super relieved it fits, but I am going to have to make up some kind of heat shield. ![]() ![]() ![]() Got my rear coliovers sorted finally too, super happy I bought new/updated boots for them because the original ones were ripped into a million pieces. Not sure why, but the green and gold looks so damn good ![]() ![]() ![]() And some random pictures I took while messing around today... ![]() ![]() ![]()
#44 | |
Man I wish I had the budget to go VE, but I just couldn't swing it right now. Plus I already have manifolds, fuel rail, S14.5 cover etc for the DET head. This head is great though, flows on par with a P11 head so it won't disappoint. Sent from my OnePlus 5T using Tapatalk
#48 | |
Thanks!
Can't wait for the TE's to get fitted up, going to out my fender roller and my patience to the test for sure. I haven't made any progress lately, been super busy helping friends with their projects and work, but I did take some of my turbo setup for ceramic coating recently. Came out awesome, should help keep engine bay temps down a good bit. ![]() ![]() Sent from my OnePlus 5T using Tapatalk
#49 | |
But in the end you are going to appreciate this much more than a VG. The amount of bustle knuckles to remove the radiator cap, 250+ lbs off the front end and 25 miles of vacuum lines........Need I say more?? ![]() |
#50 | |
#51 | |
Powertrix stuff is top notch. This is the second set of their coilovers I've owned and love them. I'm also running their front upper control arms, I actually got an old revision set from CZP when I bought them and Charles over at Powertrix sent me the revised collars no questions asked free of charge. They take care of their customers and I would highly recommend any of their parts. Sent from my OnePlus 5T using Tapatalk
#52 |
Welp I haven't touched the car in months now, but motivation is starting to come back with some big stuff happening.
After having to replace everything but the block, my SR is together and ready to rock! Huge shout out to Juan at Bardabe Performance for getting it back together. Run down on the motor is: S13 SR20DET block WPC treated crankshaft WPC treated Nissan OEM main and rod bearings Nissan OEM oil pump w/ WPC treated gears CP 86.5mm 9.0CR pistons Manely Rods Sianar Motorsports -10AN breather Nissan OEM main bolts Nissan OEM timing components ATI super damper 180SX head ported & polished by Port Flow Ferrea dual valve springs Ferrea +1mm valves Dual guides Tomei 260 procams Apexi head gasket Mazworx ARP Headstuds S13.5 valve cover w/ -10AN fittings ![]() ![]() ![]() ![]() ![]() On top of all that good stuff, I am also changing up the turbo setup. The TD05 would have been fun, but as the motor got finalized I really decided I wanted more and just happened across a Garrett G25-550. These caught my eye when they were released, but I didn't think I'd ever get my hands on one. New manifold is getting ordered this weekend and I am moving to a 44mm wastegate to make sure I can control boost properly. Haven't seen one of these on an SR, should be fun to see what kind of power it'll make on ethanol ![]() ![]() ![]() ![]() More parts will roll in soon, basically making sure I am hording everything I need so when it finally cools down I can slap this thing together and enjoy it without the risk of heatstroke ![]()
#53 |
![]() Join Date: Feb 2007
If you don't mind, could you tell me what the WPC treatment set you back? You can PM me if you don't want to say. I plan on getting my motor done as well.
Nagasaki Motors![]() Friends help you move. Real friends help you move bodies. |
#55 | ||
Sent from my ONEPLUS A6003 using Tapatalk
#56 |
dont throw away cracked head, you can get it fixed, see here
http://artsautomotive.com/publicatio...cylinder-head/ |
#57 |
The SR20 is back home and more parts are on order, once this hellish heat calms down a bit it'll be go time.
#58 |
New manifold is here, so I did some mock up to see how everything fits in the engine bay. As with all Future Fabrication manifolds, Jon killed it with this beauty. With the G25-550, proper boost control was something I was worried about, I mentioned this to Jon before I ordered the manifold and he made sure it wouldn't be an issue with a massive outlet to the 44mm WG flange. Should be able to easily control boost for a 91 map.
![]() ![]() ![]() Super happy with fitment in the engine bay, have tons of room to properly route the downpipe and dump tube and I think I may be able to run a Powertrix front strut bar. ![]() ![]() ![]() Also couldn't resist throwing the turbo onto my actual motor, gets me so hyped to get the car together! Was kinda of worried that the turbo may look small being a T25 frame, but it looks right at home thanks to how this manifold is setup. ![]() ![]() ![]()
#60 |
![]() Join Date: Mar 2005
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
Everything is coming along pretty awesome man! You're probably going to get yours back on the road before mine is! LOL
96 S14: Grip Track Car 90 R32: Bucket List Car 92 S13: Just for Fun Car Instagram: @SS.Maxey |
