![]() Join Date: Feb 2002
Sup All
If I could get some info on the MAX Wheel/Tire combo I can have without my wheel's rubbing I see alot of 235-40-18 (front) and 265-40-18 (rear) tires on on the web for our 240's |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Nismos14 on 11:35 pm on Feb. 2, 2002
235's in the front may rub without spacers and 265 will rub in the back without spacers</td></tr></table><span id='postcolor'> Depends on the car and offset. S13's won't support those widths without flares. I've seen numerous S14's with those widths, no flares. Of course if HA coilovers are run you bite into width as well, so it depends on the set-up. |
<a href="http://www.executivecleancar.com/240/
17" target="_blank">http://www.executivecleancar.com/240/ 17</a> by 8 in front (off-set is +38) 17 by 9's (off-set is +42) in the rear. 235/45/17 in front 255/40/17 in the rear No spacers mentiond --------------------------------- Also from <a href="http://www.sportcompactcarweb.com/index.jsp 18x8.5" target="_blank">http://www.sportcompactcarweb.com/index.jsp 18x8.5</a> front 18x9.5 rear 235/40/18 front 265/35/18s in back No offset mentiond but i'm sure there is some. ---------- And another 235/35-18 front 255/35-18 back No idea on wheals not mentiond ------------------------- More 19x8.5 front 19x9.5 rear 235/35/19 front 265/30/19 rear another with not enough detail ______________________ What is off-set anyways i'm kinda lame when it comes to Wheels and Tires. |
![]() Join Date: Nov 2001
you can search zilvia for offset stuff otherwise go to tirerack and look at their stuff
http://www.tirerack.com/wheels/tech/offset.htm also, 19s seem real big for the 240, so it kinda depends on if you are going for the big wheel look (which is fine) or pure performance. I'd stick with 16-18" wheels for this tire outside diameter. Also, most people seem to like what they have and 16-18 is most common. Adam |
![]() Join Date: Dec 2001
since we are on the topic. wil 17x7 or 17x8 fit my s13 w/o spacers? i'm thinking about either getting 17x7 or 17x8 or 16x7, but i don't know which is the best choice
