Prev Previous Post   Next Post Next
Old 06-23-2018, 06:35 PM   #1
G2Composites
G2Composites is an unknown quantity at this point
G2 Carbon S13/S14 Broken Window Trim Fix
I've been around 240's for a long long time and I have to say about 75% of them ALL have a broken window switch trim on drivers side, passenger side or BOTH.
The poorly designed a thin plastic window trim could not hold up to 25+ years of abuse. So I designed a fix. This solution bolts through the broken part of your window switch trim and holds the entire trim in place to the original hole inside the door panel. Easy bolton solution. Its sturdy, effective and even comes with a plastic screw cover so you dont see any unsightly screws inside your window switch trim.
S14 Version:
S13 Version:
I am selling a set of these window trim solutions for both sides with screws and screw covers for $55 shipped. They are different for S13/S14 applications so DM me if you are interested.
G2Composites is offline   Reply With Quote
fix, s13, s14 window trim
