#91 |
Lordrandall: MWS Motorsports sells a kit for the 300zx that is suppose to fit under 16" wheels but runs $550. pm me the info, i think i know who you are talking about.
I still havent heard anything from the machine shops that i have contacted. hopefully i can get those hubrings started this week. |
#92 |
oh yeah i forgot to mention this but those of you with Q45/J30 calipers can use this kit as well. Use of the q45/j30 calipers may allow for a smaller wheel as well but not sure how much smaller.
#94 |
Any word on this? I saw the thread about your fire, sorry about that dude. Hopefully you can rebuild with that other S13. And rock some mega 13" cobra rotors on it
S13, SR20 - Track day fun |
#99 |
i have 5 sets of brackets ready to go but no hub spacers so until i get those i wont be selling the brackets. sorry guys i've learned that machine shops are hard to deal with. hopefully i can get these out for you guys. I'll keep you all updated though
#100 |
Please pm me when they're ready.
I'll take a set of cobra to z32 adapters asap.
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: #/f/tech-talk/147301...d-gto-pan.html |
#101 |
![]() Join Date: Jan 2007
pm me when there ready ill probably be up for a set .. please pm me ur contact info as well as location and so on so that when there ready i can just pick a set up =-)
#102 |
Can Maxima guys use your brackets for their 300ZX/Cobra swaps?
Also, I hear if I have a 4-lug, I don't need the hub centric ring, as I'll be re-drilling the rotor, and the new holes will center it just fine. sil80 |
#103 |
Depends on how he made the bracket. But there's already a guy on Maxima.org that makes a bracket for Maximas and the hubcentric ring.
I have car? |
#104 |
![]() Join Date: Jan 2004
i just want to confirm, i have the complete R33 rotors and hubs on my car. this kit will work as well right?
i'm still interested. hell, i can try it out for the price. |
#105 |
I would suggest the hubcentric rings even with a redrilled rotor for a 4 lug.
I will have the r33 kits as well, its a little different than the z32 kit, but i will have both. |
#106 | |
He also says that although his brackets look similar to the ones Tim makes, for Maximas the spacing may be different, and the caliper will sit oddly offset toward the rotor when used on a 240SX.... but I was under the impression that both Tim's and Jeff's brackets were the same exact thing, dimensionally (3/8" thick, same bolt spacing, etc). Can you comment? sil80 |
#109 | |
Yes, the spacing may be a bit different because you have to shave 3mm off the radius of z32 rotors to fit z32 calipers on a Maxima. So there is a 3mm difference there between z32/240sx/J30 and the Maxima. You could technically run Jeff's brackets on a 240sx with the Cobra rotors, but you would have more pad overhang that would be optimal. Best to make custom brackets for the RWD Nissans.
I have car? |
#111 | |
![]() Join Date: Mar 2004
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
http://www.blehmco.com/brakes.htm
LSX Kouki Project, swap completed in Dec 09 |
#112 |
Timtiminy, I'm having my friend contact you, he has access to some machine shop equipment and could probably get rings made up for you if you have dimensions. Clearly, I want to get these things on my car.
#113 | |
Maybe he'll make a similar kit for his 240. ![]()
I have car? |
#115 |
Its been done for a long time, and alot of Z32 guys are rocking the 13'' stang rotors..
Guy in FL named Ash makes the brackets. http://www.ashspecz.com/ashspec/brakes/brakes.htm |
#116 | |
91 Sil80-Sold, LS2 Powered 1997 240sx-Traded, 2005 350z-Sold, Whats next? |
#118 |
I have the whole kit for the S13 for sale. I tested it and it worked great.
Please see my thread: #/f/sale-items/21189...-tein-jic.html sil80 |
#119 |
![]() Join Date: Jul 2007
seems to me this rotor is too large for the caliper.. how this would stop any better than a z32 rotor that has a full contact patch? z32 calipers using a z32 rotor: I fail to see how the cobra rotor could stop the car any quicker than the z32 setup, after all you are using the same caliper and the contact patch between the rotor and the brake pad have not been increased. the use of your brackets actually decreases that patch by what did you say 1mm? here is a STi setup with EVO rotors: STi calipers have a larger brake pad and properly fit the EVO rotors ![]()
#120 |
The reason people go with the Cobra rotor is because the AREA of the rotor is larger than the 300ZX rotor. The contact patch is the same, for both rotors, the pads are completely covered by the rotor (for the Cobra upgrade this requires slight grinding of the caliper edges so that they sit closer to the rotor).
Bigger brake upgrades are very rarely about stopping faster. Stock 240SX brake are sufficient to lock up the wheels (which means all the braking power you need to stop). Nowhere in this thread have people claimed faster stopping times. The advantage of bigger brake rotors and pads lies in their heat dissipation abilities. Being able to stop from 100-0 is no large feat. Being able to do so multiple times over without experiencing brake fade and fluid boiling is what counts. This is achieved by maximizing the area of the rotor and pad. The EVO/STi combo is also great. The EVO rotor is not 13" though, so fade may occur faster. sil80 |
