s13 idling issue after EGR delete
Hey guys so I needed to do an EGR delete, plate is on, and the hole is plugged. Finally got the car to turn on and idle for a while, but it's idling around 2,000 now rather than 1,000. After letting it sit for about 2 minutes it drops down to like 600rpms and sounds like it's about to die. I can give it some gas and it'll save it but still, that's not supposed to be happening. There are no leaks as far as i can tell, i had a few but i fixed them. The hoses are connected, the plugs are all the way tight and there is no air seeping from the egr plate blockoff. There is a slight exhaust leak at the beginning of my cat delete that i will worry about later, but i know that shouldn't be the issue considering last week i was running the car with not even a downpipe on it and had no idle issues.
Before you try to link me to a EGR Delete thread/guide, I have looked at multiple different guides and i have double checked the leaks it had told me to check, - that fixed the other problems i was having, i'm having different ones now I believe. I have also cleaned out the IAC with intake NOT CARB cleaner, and so far nothing. I drove the car and it seemed perfectly fine, besides when i was at a stop i needed to rev a little every once in awhile to make sure it didn't die out on me.
Thank you
